Phil and Micky Posted May 23, 2015 Report Share Posted May 23, 2015 I have a 2005 Phaeton and am getting an occasional "check engine" light. It goes off after awhile. Is there away that I can extract the fault code so that I can find out what is going on? Link to comment Share on other sites More sharing options...
Dale P Posted May 23, 2015 Report Share Posted May 23, 2015 If your rig has the MMDC then yes. Need to go into service mode I believe. Or you can try the Set Speed for your Curse Control. Turn Key to the "On". Press and hold the set speed. The check engine/service engine light will flash. Of Why not call Freightliner 24/7 Hot line? Link to comment Share on other sites More sharing options...
Phil and Micky Posted May 23, 2015 Author Report Share Posted May 23, 2015 I tried the cruise control thing without any luck. I'll try to find the phone number. Thanks Link to comment Share on other sites More sharing options...
