... Posted May 13, 2015 Report Share Posted May 13, 2015 I have a small compartment with a broken door. It looks easy enough to replace if I can find a match. The overall size (outside to outside) is about 7.5" x 12.5". I've attached photos. I've not yet found one online, but I'm probably looking for the wrong search term. Does anyone have a clue to lend? The hinge in the frame is broken, so I expect I'll need the entire frame and door as a unit. Link to comment Share on other sites More sharing options...
socaltoolguy Posted May 13, 2015 Report Share Posted May 13, 2015 You may have to replace the entire compartment frame and door as an assembly. What type/brand is your rig? A lot of this stuff is still available from the manufacturer. Our mh is an 01 and we can still buy a ton of stuff from Fleetwood. Ray Link to comment Share on other sites More sharing options...
Devilishjim Posted May 14, 2015 Report Share Posted May 14, 2015 If you cant find one I'm sure a sheet metal fabricator could build one for you. Jim Link to comment Share on other sites More sharing options...
Devilishjim Posted May 14, 2015 Report Share Posted May 14, 2015 Or grind the hinge out and pop rivet a piano hinge in its place ? Link to comment Share on other sites More sharing options...
rdickinson Posted May 14, 2015 Report Share Posted May 14, 2015 Found this, it seems they will make a complete door and frame to your requirements. Just pick the style and send them money. www.pellandent.com 7-3/4" x 12-5/8" Multi Purpose Hatch without Back Your Price: $77.66Model Number: 21-ZE213-ATime To Ship: 2 days Multi Purpose Hatch without Back Made from fade and impact resistant plastic, can be painted Cut Out Dim. 6" x 11-1/16", Outside Dim. 7-3/4" x 12-5/8", Collar Depth: 1-1/8" the link doesn't work but I think this is the hatch. The radiused corners look the same. Link to comment Share on other sites More sharing options...
... Posted May 14, 2015 Author Report Share Posted May 14, 2015 Thanks Roger! Looking at the measurements and the number of scew holes, I agree, that looks like the exact hatch cover. Perfect. I'll get it ordered. Link to comment Share on other sites More sharing options...
Dennis M Posted May 14, 2015 Report Share Posted May 14, 2015 Look like Roger solved your problem, but another place to look would be Colaw RV Salvage Link to comment Share on other sites More sharing options...
... Posted May 14, 2015 Author Report Share Posted May 14, 2015 Update: Based on Roger's research, I did a little decoding of the part numbers and found it on Amazon for $44 w/ free shipping. It's the exact item Pellandent lists for $78 + $20 shipping. http://www.amazon.com/JR-Products-ZE102-A-Multi-Purpose-Access/dp/B007HRTSBG Just in case someone else stumbles on this same problem later. Link to comment Share on other sites More sharing options...
rdickinson Posted May 14, 2015 Report Share Posted May 14, 2015 Either way it is a win, win situation. The problem was solved. Link to comment Share on other sites More sharing options...
