what airline for hayes?
PEIFamily
After searching through 37 results, and reading the resource guide I still am not 100% sure what airline to use on the install of the hayes on a 2006 Volvo 670.
I see Bill used the gray line, but Qlstar tried that one and had no luck? Anyone know the one needed for this year truck?
Tested the JACKALOPEE last night, works great, so got to bolt it to the truck tomorrow and need to get the hayes installed by Saturday when I need to move the RV 30 miles.
Thanks
Jason
Just like the MakBrake and BrakeSmart Controllers, you want to use the air line to the Stop Light Switch. From the Tractor Protection Valve, this line is 1/4" Black.
In the Gen I Volvos, after going thru the firewall access, the Black line went to the Stop Light Switch. On the Gen II Volvos, the Stop Light Switch was moved to the pass thru manifold making the tap harder inside the firewall.
The reason for the Black Line from the Trailer Protection Valve is that it gets air pressure from either the right or left brake system. You can tape either the right or left system and it will work. The problem would be only in the extreme case where you lost one side and that is the one you picked for the Controller.
All this is covered in the Resource Guide conceptually. If you were looking for specific pictures of a Hayes Controller in a Gen II Volvo, you are out of luck as no one has submitted photos of their install.
RV Cable Grip
RV Cable Grip
RV Air.
