MsChrissi Posted May 1, 2015 Report Share Posted May 1, 2015 2000 VNL-770 ...what does it use for clutch reservoir fluid? (assuming that is the little reservoir outboard of the steering column) Link to comment Share on other sites More sharing options...
HERO Maker Posted May 1, 2015 Report Share Posted May 1, 2015 I was pretty sure that it was Dot 3 fluid that was put into mine. I will check tomorrow. Is it taking it's own sweet time in engaging when you fully depress the clutch? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
kyote Posted May 1, 2015 Report Share Posted May 1, 2015 Volvo calls for Dot 4 brake fluid. I did some research a couple years ago, and it seems there may have been a rubber incompatibility issue using anything else. Mine was pretty black also, so I just replaced the slave, master and hose because I couldn't clean the black gunk out of the system. Nasty dirty job! I have a 2000 660 Al Link to comment Share on other sites More sharing options...
VegasFlyer Posted May 1, 2015 Report Share Posted May 1, 2015 The last thing that anyone wants, is a "rubber incompatibility issue"! Just sayin...... John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
Rick & Alana Posted May 1, 2015 Report Share Posted May 1, 2015 Mine was leaking also. Had read Marks comments on having the assembly fail and a tow bill along with repairs. When I had to start adding fluid more often I just went ahead and replaced the master cylinder, hose and slave cylinder on my schedule. Not its Thanks Mark for the write up and warning. Rick and Alana Fulltimers 2018 Newmar Ventana 4037 2020 Jeep Gladiator 1997 Jeep TJ 2009 Mobile Suites 36RSSB3 formerly owned 2000 Volvo 770, 600 Cummins ISX,18 speed autoshift, 14 foot "garage" ET,Jackalopee,MaxBrake,Pressure Pro pro www.rickandalanasgreatadventures.blogspot.com Link to comment Share on other sites More sharing options...
Bill B Posted May 1, 2015 Report Share Posted May 1, 2015 2007 - 780 - DOT 4 Bill and Cecil2007 Volvo 780 Motorhome - Autoshift 3 Trans | 2003 38' New Horizons 5'erPhotobucket Pictures Link to comment Share on other sites More sharing options...
SIBERNUT Posted May 1, 2015 Report Share Posted May 1, 2015 When you bleed it, you either need a pressure bleeder or you need to "trick it" since the bleed screw is at the bottom of the cylinder 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
MsChrissi Posted May 1, 2015 Author Report Share Posted May 1, 2015 So far not a noticeable leak, just low on the reservoir marks. DOT 4, okay. Thanks guys! Link to comment Share on other sites More sharing options...
HERO Maker Posted May 1, 2015 Report Share Posted May 1, 2015 So now I'm with the rest of the guys. Took a look and Dot 4 is all I have for it. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
HERO Maker Posted May 1, 2015 Report Share Posted May 1, 2015 So far not a noticeable leak, just low on the reservoir marks. DOT 4, okay. Thanks guys! Is it not engaging? Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
MsChrissi Posted May 4, 2015 Author Report Share Posted May 4, 2015 MsChrissi, on 01 May 2015 - 4:38 PM, said: So far not a noticeable leak, just low on the reservoir marks. DOT 4, okay. Thanks guys! Repeat...no problem experienced, just a slightly low reservoir. Thanks for your concern. Link to comment Share on other sites More sharing options...
