redcrzr Posted April 29, 2015 Report Share Posted April 29, 2015 Multiple issues, unable to find the solution in the HHR Guide. I am changing out the drivers side mirror with a better used one. Rather than trying to take the full (rusted) mounts off I have opted to remove the "guts. I have taken out the 6 allen screws that hold the mirror on & now cannot remove the antenna fitting. Pretty much made junk out of it. Would it be an option to cut the cable & splice? If so, where do I find the proper splice fittings? To add to the issue I fried the cable that ran to the CB all the way down to the box. That occurred on the way to the HDT Rally 2014. Ask my wife how exciting that was. Would a new/used multiplexer & cables be a better option and if so, where do I find one? I've been searching the truck parts on google with little or no luck. Todd E. Link to comment Share on other sites More sharing options...
Bill B Posted April 29, 2015 Report Share Posted April 29, 2015 I don't know Todd - But the multiplexor box is behind the panel next to the throttle pedal. Link to comment Share on other sites More sharing options...
kyote Posted May 2, 2015 Report Share Posted May 2, 2015 Todd, check your messages. Al Link to comment Share on other sites More sharing options...
redcrzr Posted May 2, 2015 Author Report Share Posted May 2, 2015 Al I replied to your PM. I ended up cutting the antenna wire & putting in a "splice". Probably not the best but rust was an issue in the process. Thanks for your efforts. Todd Link to comment Share on other sites More sharing options...
