kidder Posted April 29, 2015 Report Share Posted April 29, 2015 Hi Everyone, Next thing on my list of things to do is to get the truck ready for putting in a dash monitor and backup camera. I am looking to move 4 dash switches (jake brake, 5th wheel switch (no longer used), rear dump switch, and one other --- all sit right below the main fuse box and above the radio. I want to move them to the panel which sits to the right of the steering wheel but left of the vent. This darn vent sits right between the two panels . I know a number of people have done this and am looking for some advice. Looking at the switches that need to moved they sit right below what looks to be the main fuse box. So from what I can see I am probably going to have to remove the fuse box and potentially even the vent and run the wires either behind the vent or underneath? If anyone has any words of wisdom, pictures, or just suggestions, I am ALL EARS . Or can point me in the direction of such - it would be great appreciated. If no one has documented this with pictures, I will do this and post to the group when completed. Thanks in advance. Curt Link to comment Share on other sites More sharing options...
The Few Posted April 29, 2015 Report Share Posted April 29, 2015 WOW, what a great Idea.. Would love to know more about that project myself... I don't have a truck "YET", but I am building up all this valuable information from you folks to construct the truck I want.. Thank you sir!! Link to comment Share on other sites More sharing options...
SIBERNUT Posted April 29, 2015 Report Share Posted April 29, 2015 Well, I moved my Jake switches (2) and my trolley brake to my gen 1 AS pedestal. Put the gear indicator in where the trolley was. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted April 29, 2015 Report Share Posted April 29, 2015 Curt, Will see if I can find pictures to post but I did exactly what you propose. My backup monitor sits in the dash below the fuses and moved all my switches one space left. The connections all move very easily and should present no issues. Looks like it came from the factory that way. Link to comment Share on other sites More sharing options...
RickW Posted April 29, 2015 Report Share Posted April 29, 2015 I re-arranged mine. The switches just pop out. I think all I had to cut was one zip tie so that the wire on the one switch would stretch to where I wanted it. The whole project of moving the switches took under 5 minutes. Link to comment Share on other sites More sharing options...
MrSeas Posted April 29, 2015 Report Share Posted April 29, 2015 Yep, one of my easier mods....... Link to comment Share on other sites More sharing options...
Big5er Posted April 29, 2015 Report Share Posted April 29, 2015 All of your switches will have enough wire to move over there. If you look to the far left you will see my engine brake switch. Link to comment Share on other sites More sharing options...
kidder Posted April 29, 2015 Author Report Share Posted April 29, 2015 All of your switches will have enough wire to move over there. If you look to the far left you will see my engine brake switch. Big5er - thats exactly what we want to - and our dash looks identical. Did you have to pull the fuse box at the top to pull them behind the vent OR ?? By the way, love how you installed the monitor - will have to talk to you about that as well . Thanks, C Link to comment Share on other sites More sharing options...
SuiteSuccess Posted April 29, 2015 Report Share Posted April 29, 2015 Curt, You do not have to pull the box. My setup is just like Big5er and there is plenty of length on the wires like Rick said. Can't get my pics to upload. Link to comment Share on other sites More sharing options...
Big5er Posted April 29, 2015 Report Share Posted April 29, 2015 Curt, that A/C vent pops out too, so you can just work the wires around the end of the duct and you are there. That piece of wood trim pops off, start at the steering wheel side, and exposes all the screws that hold the pieces in. You can unscrew the piece where the monitor is, reach behind and push out the A/C vent, reach thru that hole and push out the next section. Once you remove that wood trim it is all sorta easy. You will see what unscrews and what pops out. I had a friend that took the original bezel for the switches, used a dremel tool to cut out a hole for the monitor, glassed the monitor in place and covered it with vinyl. So the monitor uses all the original tabs and screws to mount. He works at "Car Toys". They do all kinds of custom stereo stuff. I did all the rest but glassing the monitor in the Volvo bezel was way beyond my skill. Here is a broader picture. I moved the ones from the monitor area to the left, and moved the ones that were located where the Sirius is to the spot right next to the steering wheel. Link to comment Share on other sites More sharing options...
kidder Posted April 29, 2015 Author Report Share Posted April 29, 2015 Thanks Guys. I actually went ahead before the two of you posted - hehehe. Both of your posts are 100% accurate. Once I removed the wood trim ... it was easy to get the vent out, and everything on the dash just naturally came out - so it made it really easy. The fellow who had the truck before us obviously had a bunch of other stuff added onto the truck because there are a number of wires in there that it is easy to see are "add ons". It was good to get back there ... clean it all up . If anyone is interested, I took a bunch of pictures. I can post them which shows pretty much the entire job. Great idea on getting someone else to do the bezel Big - that is probably what I will do . Thanks again everyone. Nice to get another item off the to do list. Curt Link to comment Share on other sites More sharing options...
HERO Maker Posted April 29, 2015 Report Share Posted April 29, 2015 Has anybody done anything similar to the gen 1 trucks? With pictures? Link to comment Share on other sites More sharing options...
RickS Posted April 29, 2015 Report Share Posted April 29, 2015 Phil, I think that is the same monitor that I have. I was in quite a hurry last season and just left a switch cover out and pulled the wire through the hole. I attached the monitor to the top of the switches with industrial velcro. That bezel looks great! I may have to spend some time and mount mine in dash it looks so much better that way. Link to comment Share on other sites More sharing options...
kidder Posted April 29, 2015 Author Report Share Posted April 29, 2015 Rick, What monitor do you and Big have and where did you get it - they are identical and look really sharp. Curt Link to comment Share on other sites More sharing options...
Phil D Posted April 29, 2015 Report Share Posted April 29, 2015 I did all the rest but glassing the monitor in the Volvo bezel was way beyond my skill. Thank goodness you only listed one of things beyond your skill level, Big5er. Escapees only has so many terabites of storage dedicated to the Forums. I guess that I owe you a Dr. Pepper or three the next time I see you to make amends for the insult. I just couldn't help myself. Link to comment Share on other sites More sharing options...
RickS Posted April 29, 2015 Report Share Posted April 29, 2015 Rick, What monitor do you and Big have and where did you get it - they are identical and look really sharp. Curt Got it from: Steve Gudin Leviathan Holdings, LLC 2473 S Higley Rd # 104-105 Gilbert, AZ 85295-1103 Here is eBay store. This info was given to me by Jack a few years ago and he has been great to deal with. Had some cables and a few more camera's ship from him today. Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 29, 2015 Report Share Posted April 29, 2015 Yes, Steve is the place to get video stuff. I've used him for at least 13 years. Reliable, and the stuff is very good for the price. Is there "better" stuff out there? Yes, there sure is. But for the price Steves stuff is very good quality. What size monitor is that one, guys? I have a 7" and a 9". The 7" is bigger than that one, it looks like.... Link to comment Share on other sites More sharing options...
RickS Posted April 29, 2015 Report Share Posted April 29, 2015 Mine is a 7" and it looks like Phil's is as well. Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 29, 2015 Report Share Posted April 29, 2015 Mine is a 7" and it looks like Phil's is as well. Hmmm, I'll have to get my 7" out again. What I's like to do is put in my 8.4" Samsung tablet, though. I'll get to play with that later this summer. It is about 10 major items down on my "truck list". Link to comment Share on other sites More sharing options...
Big5er Posted April 30, 2015 Report Share Posted April 30, 2015 Yup, mine is the same one that RiskS has. Phil D, normally for that one you'd need to add a little Blue Bell to that Dr. Pepper, but I'll let ya slide cuz I like ya Curt, glad ya got it worked out. Rick and Jack are right about Steve. Good guy to deal with. Link to comment Share on other sites More sharing options...
Phil D Posted April 30, 2015 Report Share Posted April 30, 2015 Phil D, normally for that one you'd need to add a little Blue Bell to that Dr. Pepper, but I'll let ya slide cuz I like ya You're on! We almost always have a half gallon of Homemade Vanilla in the freezer (when they're making the doggone stuff), so a Dr. Pepper float is entirely possible. Link to comment Share on other sites More sharing options...
RickS Posted April 30, 2015 Report Share Posted April 30, 2015 Since we are talking about camera's and monitors I'l post a link here to a manual video switcher I ordered for the truck this week. I haven't got it yet but with the spec on sizing should fit nicely in the single DIN area below my radio. I don't have one of those fancy cassette decks like in Phil's truck above. The monitor has inputs for four camera's which I will have five( Over Drom, ET Hitch, License plate, rear trailer, passenger side trailer) and the switcher will allow me to have eight if needed. Here is the link for the switcher. Link to comment Share on other sites More sharing options...
kidder Posted April 30, 2015 Author Report Share Posted April 30, 2015 Thanks again Everyone! I ordered a monitor and camera from Steve - super guy and very helpfull - he actually referenced Jack and Rick I was reading in the description of the monitor/camera setup that you can hook the monitor up so that it comes on when the truck goes in reverse. But it sounds like most everyone is hooking them up so they are "on" all the time so you can watch blind spots etc. etc. Thoughts on this? If you did hook it up for only when the truck goes into reverse - where did you tap into the reverse signal? Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 30, 2015 Report Share Posted April 30, 2015 Since we are talking about camera's and monitors I'l post a link here to a manual video switcher I ordered for the truck this week. I haven't got it yet but with the spec on sizing should fit nicely in the single DIN area below my radio. I don't have one of those fancy cassette decks like in Phil's truck above. The monitor has inputs for four camera's which I will have five( Over Drom, ET Hitch, License plate, rear trailer, passenger side trailer) and the switcher will allow me to have eight if needed. Here is the link for the switcher. Nice switch. I may end up buying it and putting it in the dash as you suggest. What I'm doing now is using a custom rotary dial that I switch three sources through and send a selected one to my 4- input monitor (the 9" from Steve). I have not totally built that out yet...it is going into a switch blank when done. But I think the DIN located- switcher might be a little easier to work with..... Curt, my monitor is on all the time. What is displayed varies depending on what I'm doing. Link to comment Share on other sites More sharing options...
RickS Posted April 30, 2015 Report Share Posted April 30, 2015 Curt, I do the same thing. I like having the back of trailer and trailer passenger side camera on when passing. The trigger wire would be connected into a reverse signal from reverse lights or on a transmission reverse signal. I never did ask if you could watch the same camera if the trigger is hooked up. Also, which one would you have as a reverse camera? Drom-Hitch-Rear trailer? I use all of those in reverse situations. I will let you know how the switcher works out. Link to comment Share on other sites More sharing options...
