2008 Saturn Vue
I sold My Mountain Aire and only have a Roadtrek so I have no need for this toad. It is complete with a Roadmaster Falcon II tow bar, baseplate, already installed US Gear brake system with the MH control. I have the switch In the glove box to eliminate removal of the fuse that eliminates standing on your head to replace the fuse. Battery is AGM and has a wire to the MH connector for charging. Tires have 20K on premium tires. Blue/green color. Includes safety cables, break away switch and everything to tow. Weight is 3400# with the 4 cyl. engine. I have probably towed it less than 10K miles total. Uses no oil. 104K miles now. I will be getting a larger car since I don't have to be under 4K for towing anything. Located in Holland, MI. bsimich@yahoo.com $8500.
RV Cable Grip
RV Cable Grip
Country Thunder Iowa
Nomad Internet
RV Air.
