Pierre1952 Posted April 25, 2015 Report Share Posted April 25, 2015 Just picked-up my 2012 Wildcat re and are both excited in starting our new life. This is our first fifth wheel so we are in the learning process. Our RV is parked in our driveway which has a small incline. I unhooked the RV from the hitch, so far all goes well. Pulled truck away, so far so good. Now I brought my leveling jacks all the way to the bottom because I was not leveled. Now I tried bringing jacks up a bit but it wouldn't go up. So I brought it up a bit manually. I pushed on electric switch and nothing happends, won't go up or down. I checked the fuse to see if it could have been blown out, but fuse is good. Am I doing something wrong here or could the motor be deffective. Thanks for you reply, every little help is appreciated Link to comment Share on other sites More sharing options...
Star Dreamer Posted April 25, 2015 Report Share Posted April 25, 2015 Check your battery to make sure you are fully charged and/or plug the trailer into shore power. If your jacks are hydraulic check to see if they are topped off. Link to comment Share on other sites More sharing options...
Pierre1952 Posted April 25, 2015 Author Report Share Posted April 25, 2015 I am plugged into shore power now and my jacks are electric. Still nothing seems to work. Link to comment Share on other sites More sharing options...
Big Greg Posted April 25, 2015 Report Share Posted April 25, 2015 Is there a thermal circuit breaker, perhaps in the battery box area, between the batteries and electric feet? Check for a small 2 or 3 inch cube with heavy wires attached that might have a flag or reset level sticking out. If so push the lever down. Greg Link to comment Share on other sites More sharing options...
Cyberdave Posted April 25, 2015 Report Share Posted April 25, 2015 Did you chock the wheels before unhooking? I learned a long time ago to always chock on even the slightest incline. That forward or backwards pressure on your jacks. When you say electric do you mean totally electric or electric over hydraulic? Â What controller do you have? Who's system is it? Lippert? Big Foot? Â There are so many combinations of landing gear out there.... Give us some more info please. Link to comment Share on other sites More sharing options...
Pierre1952 Posted April 25, 2015 Author Report Share Posted April 25, 2015 They are totally electric. Link to comment Share on other sites More sharing options...
Jimalberta Posted April 25, 2015 Report Share Posted April 25, 2015 Im pretty sure by that the OP has an electric motor driving the legs. Thats the way my Bighorn was. Â I'm thinking that you are going to need to get out your multi meter and see where you do and don't have 12 volts. It could be a fuse just before the motor ( somewhere in that circuit you will have a fuse ). Or it could be a faulty switch. Â My fifth wheel was heavy and I found that the motor was overworked so I did a mod and changed the setup so that I had a motor on each leg with a separate switch. I also think they cheap out with the wire size as well. Link to comment Share on other sites More sharing options...
Pierre1952 Posted April 26, 2015 Author Report Share Posted April 26, 2015 Found fuse box hidden between battery and motor jack, changed fuse and all is now working. Thanks for all your help. Link to comment Share on other sites More sharing options...
Jimalberta Posted April 26, 2015 Report Share Posted April 26, 2015 Perfect! Link to comment Share on other sites More sharing options...
