dsvohio Posted April 23, 2015 Report Share Posted April 23, 2015 On our first time out in our new to us 2004 Winnebago Adventurer 35 U the floor register just behind the drivers seat kept putting out heat . The toggle switch on the dash was in the off position. It toggles back and forth between low high and off. We had it level in the off position. What are we not doing right or is something broken.? Link to comment Share on other sites More sharing options...
Jim Corey Posted April 23, 2015 Report Share Posted April 23, 2015 Floor register should be from the furnace, not the chassis (dash controlled) heater. Any chance your thermostat is on, and the coach furnace cycles? Link to comment Share on other sites More sharing options...
dsvohio Posted April 23, 2015 Author Report Share Posted April 23, 2015 The dash toggle switch says coach heat and if you turn it on high more heat comes out of the register. The furnace was off. We double checked that Link to comment Share on other sites More sharing options...
kathydavidb Posted April 23, 2015 Report Share Posted April 23, 2015 Does the heat come out when not moving? The reason I ask is that mine will put out heat if the temp. setting is turned up but the blower is off. You only notice the heat when travelling. When I want just a little heat, that is what I do. Once the temp. control is turned down, the heat quits. Just a thought . . . Dave. Link to comment Share on other sites More sharing options...
Kirk W Posted April 23, 2015 Report Share Posted April 23, 2015 First, let me say welcome to the Escapee forums! We will do our best to assist and support you. I'd assume that you have a gas chassis in your Adventurer, as I don't believe that any of them ride on a diesel? Based upon that assumption, it would seem that the heat has to be coming from the front engine. I have never seen any chassis heater that supplied heat to a floor vent so I am suspicious that the problem may not be with your chassis heater but with the duct work to the floor vents. If you look in the storage bay under the floor near that vent you will probably see the duct that supplies the floor vent. That would be the first thing that I'd take a look at since it sounds as though the heat is coming from your engine and somehow entering the furnace duct-work. Have you looked at this problem with the RV sitting still? If the source is your chassis heater then turning on the blower with the RV parked but engine running should cause heat to come from the vent and the fan speed should effect the amount. If most of the heat is only when you are driving that sounds like the air is being forced into the system due to travel speed. The other thing I am wondering is if you are certain that the heat source is that floor vent? It is very possible that you have engine heat coming off of the exhaust headers and up through the floor due to not enough insulation there and not from the floor vent. I'd have someone check for air movement from that vent while driving, if you have not already done so. The exhaust headers of gas motorhome engines get very hot while traveling and will cause heat to come up through the floor unless it is very well insulated. With our gas chassis, I added additional foil wrapped, foam insulation to the floor of both the driver & passenger sides for that same issue. It was more of an issue on the driver's side in ours also but an infrared thermometer could easily detect the rise in floor temperature when traveling in hot weather until I added the insulation. Link to comment Share on other sites More sharing options...
