2013 Jayco Pinnacle + 1998 Freightliner FL 60
2013 Jayco Pinnacle 36 REQS + 1998 Freightliner FL 60 - $78,000
After many seasons of living the Snow Bird lifestyle we have decided to slow the pace down and reside in our condo in Florida. As a result we are putting our rig up for sale.
The details are listed below. The combined price for the Pinnacle and the Freightliner is $78,000. The Jayco alone is $52,000, the Freightliner alone is $26,000. We will consider separating the equipment.
You may contact me at: dpm2005inc at gmail.com or call six one three-296-2227
http://s1056.photobucket.com/user/dpm2005inc/library/
2013 Jayco Pinnacle 36 REQS (4 slides) For Sale $52,000
We are the original owners; this unit was delivered Oct. 2013. The trailer has never been smoked in nor had any pets inside. It shows as new.
  • Four new Michelin tires, Oct 2014
  • Aluminium wheels
  • Mor-Ryde CRE 3000 suspension
  • E-Z lube axles
  • Large basement (Stor-Galore)
    • 54” x 32”doors, slam latches and strut assist
    • Heated, flat floor, , 26” digital hd tv, refrigerator (bar type)
  • Sliding propane tray with 30lb bottles
  • Heated , enclosed (Uni-Dock) utility center
  • 50 amp power service with detachable cord
  • Dual battery compartment with disconnect
  • 90 amp power center with Charge Wizard
  • Generator prep package
  • 35,000BTU furnace
  • 12 gal quick recovery gas/electric DSI water heater
  • 75 gal fresh water tank
  • 85 gal grey water tank
  • 50 gal black water tank
  • Outside grille prep
  • 2 patio awnings (electric)
  • Polar Barrier Thermal Package
    • Heated fresh and waste water tank
    • Fully enclosed and protected underbelly
  • Concord Cherry hardwood cabinet construction with hidden door hinges
  • Large, split, under mounted Stonecast kitchen sink with covers
  • Water heater bypass
  • 8 cu. Ft. refrigerator with raised panel hardwood front
  • 30” residential grade convection microwave
  • Central vacuum with floor inlet
  • Toe kick kitchen lighting
  • Remote for slideouts, patio awning, power jacks, patio light
  • LED ceiling lighting throughout
  • 6”9” tall living area slideouts
  • Pleated day/night shades (main living area)
  • Command center for switches with 12v cell phone charger
  • Ceiling fan and light
  • Multi-Media Premium Sound System
    • AM/FM/CD/DVD/MP3 player
    • Toggle switch for outside speakers
  • 40” LCD HDTV (retractable behind fireplace)
  • Electric fireplace
  • Glass shower enclosure
  • Vessel bathroom sink with high rise faucet
  • Porcelain bath stool with foot flush
  • King size bed with hardwood headboard
  • Walk-in style front closet with dual hanging rods and cedar lining
  • Washer/dryer prep
  • Hardwood media center cabinet
  • 26” digital HD TV
1998 Freightliner FL 60 - 213,000 miles - $26,000
  • Original documents and line setting ticket for truck available
  • 8.3l Cummins diesel engine
  • Pacbrake Exhaust Brake
  • 6 speed Allison – MD3060
  • Tilt / Telescoping steering column
  • King cruise control with idle control
  • A/C works well
  • Block heater
  • 2 new 950 CCA batteries
  • Mountain Master Air Ride Hitch – 25,000lb
  • Rockwell 10,000lb front axle
  • Hydraulic front disc brakes
  • Rockwell 15,000lb rear axle
  • Driver controlled traction differential
  • Hydraulic rear disc brakes
  • Hendrickson 15,000lb rear air suspension
  • Manual dump valve for rear suspension
  • 168” wheelbase
  • 12” chrome front bumper
  • 2 -75 gal fuel tanks (LH&RH)
  • 255/70R22.5 Toyo rib tires on 6 polished Alcoa wheels
  • 132” conventional extended cab, with air cab mounts
  • Tinted glass in all windows
  • Dual stainless steel west coast mirrors
  • Leather Bostrom high back seats with air suspension
  • Fiberglass exterior sunvisor
  • Power windows
  • Truck has been professionally serviced on a regular schedule
Truck and trailer located near Ottawa On. Close to a major airport (YOW)
Delivery and or driving instruction available
