schneid811 Posted March 29, 2015 Report Share Posted March 29, 2015 Good Morning, I have ordered new Bilstein shock absorbers for my 2008 Damon Challenger 377 motorcoach. Has anyone replaced their own shock absorbers? Can I do this with only the levelers up or do I need a heavy duty jack? Thanks, Donald Link to comment Share on other sites More sharing options...
Jimalberta Posted March 29, 2015 Report Share Posted March 29, 2015 You dont want to be under the MH with it held up by only the levelers. Its ok to lift the MH with the levelers but then you need to block it up with either properly rated jackstands or heavy timbers. I prefer heavy timbers but good jack stands will work too and settle the MH down onto the supports. Then and only then is it safe to get underneath the MH. As far as changing the shocks what you need to do is take any stress off the shock so that it is free to come out and the new one to go in ......it might mean lifting the front tire a bit or lowering it untill the shock has no stress on it. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Phil Saran Posted March 29, 2015 Report Share Posted March 29, 2015 If you do not have a heavy duty jack and some good jack stands or big blocks of wood and aircompresser & air tools I would say you would be better off paying a shop to do the new shocks install. Phil & Alberta Saran 2019 Keystone Cougar 30RLS 2012 Dodge Ram 3500 4x4 diesel Colorado Link to comment Share on other sites More sharing options...
Kirk W Posted March 30, 2015 Report Share Posted March 30, 2015 I replaced mine on a Ford F-53 chassis and it wasn't all that difficult to do but you would be wise to have an air driven impact tool for the removal. We did mine by lifting it with the leveling jacks to get better access, but did put jack-stands under it as well. You don't really need to lift the RV other than to get better access to the upper mounting bolts. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Jim Corey Posted March 30, 2015 Report Share Posted March 30, 2015 I replaced the front shocks on my Ford F53. Quite easy. Yes. Use jack stands. Started to replace the rears. Clearance getting in with wrenches, and my creaky body, said "Let the shop do those!" We must be realistic on what we can, and should do. What was simple 10 years ago isn't quite so easy now. Jim Corey 2006 Monaco Monarch 30 pdd '12 Honda CRV toad Link to comment Share on other sites More sharing options...
Kirk W Posted March 30, 2015 Report Share Posted March 30, 2015 We must be realistic on what we can, and should do. What was simple 10 years ago isn't quite so easy now. Sad bit true............ I have pretty much quit getting up on the RV roof now and often pay a tech to do things that I once considered to be easy. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Jim Corey Posted March 31, 2015 Report Share Posted March 31, 2015 Funny, I used to fling 80# sacks of concrete. Now I am waiting for the 10# sacks to come to market! Jim Corey 2006 Monaco Monarch 30 pdd '12 Honda CRV toad Link to comment Share on other sites More sharing options...
