Jimalberta Posted March 21, 2015 Report Share Posted March 21, 2015 I discovered that torque on my MH does not improve with rpms. We were making that long climb out of Laughlin and started gaining on a Dutch Star half way up. I had it in manual and was doing about 2200 rpm and was making very little gains on this other MH and didnt want to tie up the left lane but wasnt happy having to ease up and follow him as he was slowly slowing down. Finally I geared up one gear and dropped to 1600 rpm and the MH took off and passed the Dutch Star with ease. Lesson learned .....keep the rpms in the torque band which for me is 1200 to 1600 rpms. What do you guys find as your best power band? <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Ronbo Posted March 21, 2015 Report Share Posted March 21, 2015 2200 was probably bumping the governor. That high rom is not good for the engine. Let the computer do the shifting and enjoy the ride. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Ray,IN Posted March 22, 2015 Report Share Posted March 22, 2015 Usually torque peak is around !,400 rpm. Peak HP is around 2,100rpm. As you found, peak torque works the best for pulling. The reason to run at higher rpms is for increased coolant circulation, and increased fan rpm, both to prevent or reduce overheating the engine. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Jimalberta Posted March 22, 2015 Author Report Share Posted March 22, 2015 Interesting Ray....know what you mean on the coolant circulation but with a side radiator my fan runs independant of the engine rpm. I have never seen my heat guage move up from normal. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
mohamer Posted March 22, 2015 Report Share Posted March 22, 2015 Yep, those big diesels love the lower rpms. Around 1500 rpm and pull like a train. The really big diesels run at 500 rpm on the big generators and such. Let it grunt a little. Southwind 35P ARS KB0OU EX Submarine driver Link to comment Share on other sites More sharing options...
Biker56 Posted March 22, 2015 Report Share Posted March 22, 2015 For climbing with my ISB it works best at 2,000 to 2,200 RPM with the rear radiator to keep things cool. On 6% hills 5th gear around 45-50 MPH. It can also run at 2,500 RPM all the way. But I am never in that much of a hurry. Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
nana25k Posted March 22, 2015 Report Share Posted March 22, 2015 We try never to go over 1500 rpm. That's the sweet spot for ours. Oh well except on Powder River Pass. Now that was a newbie learning experience for me!!! Ron & LindaClass of 20072000 Monaco Diplomat 2005 Honda Element"Do what you can, with what you have, where you are" Theodore Roosevelt"We can't control the wind, but we can adjust our sail""When man gave up his freedom to roam the earth, he gave up his soul for a conditioned ego that is bound by time and the fear of losing its attachments." Link to comment Share on other sites More sharing options...
SIBERNUT Posted March 22, 2015 Report Share Posted March 22, 2015 Torque peak and HP peak can vary on engines. Get the SNO off YOUR engine & call the engine mfr, most of them can give it to you. Or, a (engine brand) dealer should be able to access your particular config. And, can tell you if it can be bumped up, etc 2000 Volvo 635 A/S, N-14 Cummins"The Phoenix"'03 KA 38KSWB http://s918.photobucket.com/user/sibernut/library/?sort=6&page=1Furkids- Sibe's CH. Sedona & Tseika Link to comment Share on other sites More sharing options...
Jimalberta Posted March 22, 2015 Author Report Share Posted March 22, 2015 My engine is a Cummins 8.9 ISL. 370 HP , 1200 ft lbs of torque at 1300rpm. Exhaust brake...wish it was a jake.....Allison is set to drop to 4 th on engine brake activation. I like to travel at about 58 to 60 mph. Usually keep the economy mode on...less up and down shifting on hills. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
docj Posted March 22, 2015 Report Share Posted March 22, 2015 If you look at the HP and torque curves for these diesels you will notice that they are rather different than those for gasoline engines. The first thing you notice is that rpm cutoff is much lower than you are used to; the comment about 2100 being a governor stop is probably quite accurate. The next thing you notice is that the torque curve is rather flat over much of the rpm range; in fact some diesels will exhibit their highest torque just before stall speed. This is what gives big diesels their incredible pulling power; the slower they turn the more torque they have! With my CAT C12 the torque peak is down around ~1100 rpm and peak HP is in the 1700-1800 range. With my gearing I can run 65 in 4th and I find this a delightful gear to be in when either climbing or descending hills. For climbs this puts the engine at ~1600-1700 rpm just below the HP peak. Locking it in 4th also keeps the Allison from hunting from one gear to another. On long, steep descents by being in 4th before the Jake engages eliminates the downshift "jolt" and the Jake simply goes on and off as I touch the accelerator. Each MH will be different depending on the gearing, weight and engine size. For example, my friends with the larger Beaver Marquis in the same period as mine are geared higher so they can't go above ~57 in 4th so this strategy isn't as useful for them. As you get used to your MH you will find what works best for you. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Ronbo Posted March 22, 2015 Report Share Posted March 22, 2015 Here is a chart http://www.dwclutch.com/D&W/D&W%20Clutch%20&%20Brake%202/CUMMINS%20TORQUE.pdf Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Ray,IN Posted March 26, 2015 Report Share Posted March 26, 2015 Interesting Ray....know what you mean on the coolant circulation but with a side radiator my fan runs independant of the engine rpm. I have never seen my heat guage move up from normal. I know, I have a Spartan MM GT chassis. My heat gauge will climb to ~220 on a hard pull when turning about 13/1400 revs, but if I manually downshift to bring rpms up to ~1800, the increased coolant flow will lower the temperature back to just under 200, which is where it normally stays when on level ground during summer. 220 is still not enough to trigger the fan solenoid. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Jimalberta Posted March 26, 2015 Author Report Share Posted March 26, 2015 Do you find at 1800 rpms that your pulling power is still good? We bought diesel today and after the drive from Las Vegas up the Virgin River Gorge and continued climbing it seems all the way to Idaho....I got pretty dismal mileage...about 6....ouch. And that was keeping my speed at around 60 mph but it was a good pull for the engine. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
docj Posted March 26, 2015 Report Share Posted March 26, 2015 On a largely uphill climb like you just finished I don't think you can expect your mileage to be any better. Las Vegas is at ~2100 ft and, no matter what the grade of the road is, you effectively have to "lift" your MH and toad from there to whatever elevation you ended up at, not even considering all the ups and downs along the way. Physics is physics and work is work; there's no way around it, so your mileage is always going to be poor on a day like that. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Jimalberta Posted March 26, 2015 Author Report Share Posted March 26, 2015 Yeah thats kinda what I had figured ....I think the highest we saw was 6000 feet and it seemed like we were climbing the whole day. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Smitty77_7 Posted March 27, 2015 Report Share Posted March 27, 2015 Our ISL370 (now flashed to ISL400) was built by Cummins in July of 03, and in an 04 coach. Suspect our engines are very similar. (The flash to ISL400 was reported by many to be not worth the $$. Very minor changes in both the HP and Torque curve, with the exception of top end is now 400HP at the upper end of the HP curve. Plus the early side of the HP curve is a bit better too, so less need to go up in RPM to obtain HP.) I would suggest you try the same hill two different ways, and see what works best for you. 1) Climb it with the RPM being kept between 1550-1650 RPM, which should work well of you on the Torque side of things. 2) Climb it with the RPM being kept between 1850-2000 RPM, which should work well for the HP side of things. You should find that you climb the hill easier, and a bit faster, with the 1850-2000 RPM being maintained. It will also keep your coach running a bit cooler too. As mentioned, many differences between coaches with the same engine. (Coach weights; Gearing; Wind Resistance - are the big three.) MPG on long haul climbing at 6 MPG could be a bit on the low side. Our 40', with Tag added weight, runs about 7-7.5 MPG on average. (Some runs at close to 9.5 MPG, and some runs in the 6 - 6.5 MPG - so MPG does vary.) We run in California at 57 MPH. And other states very seldom get above 65 MPG. I like 62-63 MPG for comfortable cruising. But again, our coaches have variances between them. And also, learning to drive for MPG is different in a DP vs a Gasser. Slow but steady acceleration from stop. Anticipating the hill ahead, and traffic, and down shifting in time to keep RPM's in the sweet spot for hill climbing - all make a difference on MPG. Best to you on your travels. And great advice on calling Cummins with you engine Serial and getting your specific HP and Torque curve values! Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Bill Joyce Posted March 27, 2015 Report Share Posted March 27, 2015 Slightly off subject, but if you want to monitor your diesel mpg in real time, etc., I can recommend getting a VMSpc unit and using a laptop or other device to monitor the engine - http://www.silverleafelectronics.com/node/6. http://www.rvupgradestore.com/ seems to have the best prices on them, $306.25 right now. If your engine is new enough, you can get the one that works with Bluetooth or Wifi. Otherwise you need the USB version and you have to find out if you have a 6 or 9-pin diagnostics port, and a Windows laptop or tablet. It is best to get a 32-bit Windows machine, since the installation of the drivers is much, much easier. 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Jimalberta Posted March 27, 2015 Author Report Share Posted March 27, 2015 We are home now and our last leg from Idaho to home was lot better....8.7 MPG. I usually set the cruise at 62 mph and I swear that I am the slowest person on the road.....everyone goes flying by. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Ronbo Posted March 27, 2015 Report Share Posted March 27, 2015 If you look at the hp and torque curve for your engine you will find that the peak is produced at a certain rpm. Climb above that rpm and they start dropping off. More rpm does not equal more hp or torque, it equals less. If you can find a graph that overlaps them and see where they cross try holding that rpm. My peak torque is at 1200 rpm and peak hp is closer to 1800. I hold 1550 rpm and get my best mpg and can climb most hills without downshifting and cruise at 63 mph Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Smitty77_7 Posted March 28, 2015 Report Share Posted March 28, 2015 So much varies between manufacturers, that what is ideal for one coach, may not be the same for another. Key variances are of course gearing, tire size, and 'specific year and build within year' of an engine. For example, the CAPS era ISL's that the OP and I have, will vary in both HP and Torque ranges from a newer VGT equipped, or VGT and DEF equipped engine. They may all be ISL and 8.9, but they vary. Toss in other variable such as side vs rear radiator, and the real world differences of actual rig's weight when rolling down the road - and the ideal RPM and speed for MPG can vary. As FYI to the OP, as we have very similar engines, while still different coaches and mentioned above variables - my rolling Silverleaf reported MPG is best at between 63-65MPH. I shift into 6th at between 61-62MPH, and find 6th to 5th to 6th hunting takes place if I drop below 63MPH. Still recommend getting the actual Serial of the engine, and calling Cummins for your specific engine's Torque/HP curves, and then experiment when driving around those two key peak areas. Best to all, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
Ray,IN Posted March 31, 2015 Report Share Posted March 31, 2015 Do you find at 1800 rpms that your pulling power is still good? We bought diesel today and after the drive from Las Vegas up the Virgin River Gorge and continued climbing it seems all the way to Idaho....I got pretty dismal mileage...about 6....ouch. And that was keeping my speed at around 60 mph but it was a good pull for the engine. Sorry I haven't responded sooner; I've had computer ills. I get about 6 in heavy climbing too. Yes, 1,800 revs seems to work well for my MH climbing steep grades. I know ISC peak torque is 1,300 rpm, but I don't like to hammer the bottom end like that, As others have recommended, call Cummins with your engine S# and request HP/ TQ curves in order to determine your engines "sweet spot". This downloadable pdf on Cummins fuel mileage is interesting, most things are simple, but effective. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
wclogger1 Posted April 8, 2015 Report Share Posted April 8, 2015 In following this thread I have come across the following info. It may been seen before but it really speaks to this discussion. www.weisstravels.com/3.html Go to documents and Cat technical paper. I do not know how to make this a clickable link. Thanks, Bob Bob & Karen Ritchie Chase, BC when we are not RV'ing & chasing trains '06 29.5 LKTG Hitch Hiker 2 LS '07 GMC 2500HD Classic sb/srw SKP# 96746 Link to comment Share on other sites More sharing options...
docj Posted April 8, 2015 Report Share Posted April 8, 2015 In following this thread I have come across the following info. It may been seen before but it really speaks to this discussion. www.weisstravels.com/3.html Go to documents and Cat technical paper. I do not know how to make this a clickable link. Thanks, Bob Here's a clickable version of the link. I'm glad you find it useful: http://www.weisstravels.com/resources/CAT+fuel+economy+paper+reduced.pdf Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
