bigredhdt Posted March 21, 2015 Report Share Posted March 21, 2015 My air lines that are near the frame have been painted. I need to replace a leaking valve. Does anyone clean off the paint before making new connections using push to connect fittings? If so what is your process? Link to comment Share on other sites More sharing options...
phoenix2013 Posted March 21, 2015 Report Share Posted March 21, 2015 Painted, dirty, oily, old lines will not seat properly in push to connect fittings. Only two "real" solutions. replace the whole length with brand new line to give yourself two fresh ends going into push to connect fittings, or replace the offending fitting with brass DOT compression fitting with ferrule and inserts which will squeeze the old line to seal it. Link to comment Share on other sites More sharing options...
bigredhdt Posted March 21, 2015 Author Report Share Posted March 21, 2015 I was afraid of that. How do you get the lines off of the air tanks? Link to comment Share on other sites More sharing options...
Darryl&Rita Posted March 21, 2015 Report Share Posted March 21, 2015 With any luck, flexing the line will pop 80% of the paint off easy. The balance will need to be picked off with a plastic paint scraper, or similar. A fingernail works, if you're careful. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 21, 2015 Report Share Posted March 21, 2015 I've been successful in scraping off the paint with my fingernails as Darryl said. But you have to get it all. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Mastercraft Posted March 22, 2015 Report Share Posted March 22, 2015 Carburetor cleaner works to soften up the paint. Work at it with a rag and a few treatments of carb cleaner at the end where you want to make a new connection. 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
