Sold - 2005 Teton Frontier Grand + 1999 Volvo 610 -- $64,900
After 10 years of full-timing, we’re settling down in North Carolina & have decided to put our rig up for sale. It’s been a good home for all these years, and we’re sure it will be good for you.
Many details are listed below. The price for the package is $64,900; the Teton alone is priced at $49,900, the Volvo alone at $19,900; the trailer must sell first. If you'd like to know more, please contact me at: tetonvolvo at yahoo.com or NineOneNine-381-2186
Photos at: http://s288.photobucket.com/user/tetonvolvo1/slideshow/
and:
http://s288.photobucket.com/user/tetonvolvo1/story
2005 Teton 39’ Frontier Grand (3 slides/ 3 axles/ 20,000-lb GVWR) --- $49,900
Original owner -- Custom ordered -- Delivered April 2005 (The last good year for Tetons!)
Non-smokers / No pets / No kids / Carefully maintained
  • Six new Goodyear G-614 tires -- December 2013 -- under 3,000 miles
  • Aluminum wheels (6), spare is steel
  • Mor-Ryde IRE suspension
  • EZ-Lube hubs
  • 6.5-Kilowatt Onan generator -- propane fired w/dedicated 30-lb propane tank (no gasoline odors/ no gasoline to go bad/ no gasoline to gum up the carburetor) -- very low hours
  • Xantrex TrueCharge-2 60A Converter/Charger, with optional remote display mounted near bedroom stairs & battery temperature sensor -- 2012
  • Wired for inverter w/ 4 deep-cycle batteries
  • Big Foot hydraulic leveling system with auto-control -- one-touch leveling
  • Hickory Springs Big & Easy entry steps
  • Skid roller
  • 36” Big & Tall storage doors + flat basement floor + heated basement
  • Large basement: 5’2” x 8’ x 3’h = 124 cubic feet
  • Arctic package:
    • Dual-pane insulated windows -- all professionally re-built & re-sealed - 2010
    • Heated fresh- & waste-water tanks, valves & drain piping (12v & 120v)
    • Fully-enclosed underbelly
    • Floor insulation - R25
    • Wall insulation - R10
    • Roof insulation - R25
  • Two floor-ducted Dometic 31,000 btu furnaces
  • Two ceiling-ducted Penguin 15,000 btu low profile A/C-Heat Pump units
  • Two Insulated-dome Fantastic fans - kitchen & bath - w/rain sensors & wall-mounted thermostats
  • Two 40-lb propane tanks on slide-out tray
  • A&E Weather Pro 16’ 12v electric awning w/remote
  • 8’ high ceiling in main room, 6’7” high ceiling in bedroom suite
  • Hand oiled solid oak cabinets, tables, chairs & furnishings, including:
    • end table
    • 42” round oak dining table w/ 4 chairs & 18” leaf
    • 6-panel doors -- bedroom suite & commode room
    • Artwork in custom oak frames that match factory woodwork
  • Professionally built, custom-made oak window seat/twin bed with mattress covered in matching Teton fabric w/extensive storage -- four large drawers + two large storage bins
  • 27” TV in LVR w/slide-in raised panel oak doors
  • 13” TV in bedroom w/oak tambor door
  • Sony AM/FM / Cassette / CD stereo
  • Two new wall-hugger recliners
  • 42” ceiling-paddle fan in living room
  • Day/night shades w/ blackout
  • Nickel-plated wall lamps with brass accents
  • 45-ounce plush carpet
  • Moen brushed nickel residential faucets - kitchen & bath
  • Teton “Ceiling of Light” (Large fluorescent oak-framed ceiling lamp in kitchen )
  • Tile in kitchen & bathroom
  • Double sink in kitchen
  • Pantry w/24” deep pull-out drawers
  • Flip-up counter extension on end of galley
  • Suburban 12-gallon gas/electric DSI water heater w/new anode rod
  • Amana microwave -- replaced 2009
  • Upgraded Amana 3-sealed-burner range with piezo ignition and oven -- residential quality
  • Dometic 12 cf SxS refrigerator -- professionally rebuilt 2013 (new coils, plus upgraded insulation, cooling fans & baffle)
  • Built-in residential quality GE dishwasher -- all stainless steel interior
  • One-level bedroom suite, including:
    • Large 38”x38” corner shower stall w/skylight & curved glass door -- brushed nickel trim
    • Large sink w/solid oak cabinet & shelf above + cabinet & drawers below
    • Large commode room: 2’4” x 3’5” x 6’7”h
    • Sealand residential-grade china toilet -- replaced 2014
    • Vanity drawer in bedroom w/large make-up mirror & matching upholstered seat
    • Custom queen bed in king-size slide w/his & her night stands & windows + walk-around space
    • Washer & dryer hook-ups
    • Tempur-pedic-type foam mattress
    • Original Teton bedspread + pillows & shams
  • Outside hose w/ sprayer
  • Black tank flush
  • Rear receiver hitch - wired for toad lights
  • 50-gal black, 90 gal-gray, 70 gal-fresh tanks – all heated within floor/frame area
  • Audiovox hardwired rear-view camera
  • All roof seams professionally re-caulked & sealed with Eternabond tape -- main unit + all slideouts -- 2012
  • Original owner’s manuals & full documentation -- all receipts since pre-purchase
  • Issues: All aluminum wheels matched structurally, one is mis-matched cosmetically. Headliner is drooping in spots. (see photos)
  • Accessories
    • 2-stage residential-grade water filter system
    • Residential-grade water pressure regulator -- solid brass w/pressure gauge & stainless steel fittings, plus supply-side pressure gauge
    • Large-capacity water softener
    • Upgraded drinking-water hoses -- 200 psi burst rating w/solid brass fittings
    • Bike rack & cover w/supplemental LED turn/brake/running-lights mounted on rack
    • 50-amp SurgeGuard surge protector
    • 50-amp extension cord - 30’ long w/carry strap
    • HDT tire chains -- 2 pairs
    • Roto-choks -- 1 pair
    • Tripod
1999 Volvo VNL610 -- 779,000 miles -- $19,900
  • Single rear axle, 10’6” height, turns & drives better than a pick-up truck
  • Bought in 2005 w/705,000 miles (cousin to Jack Mayer’s VNL610)
  • 450 hp / 1650 ft-lbs Cummins N14 Celect Plus (Red Top)
  • 10-speed Eaton Autoshift -- 3 pedal
  • Easy Pedal clutch
  • 3-stage Jake brake -- engages +2, +4, +6 mph above cruise setting
  • 9.5 mpg towing; 12.5 mpg bobtail
  • 200-gallon fuel capacity -- tanks now full!
  • Wheelbase: 188”
  • Color: White -- professionally painted 2005
  • Alcoa aluminum rims -- recently detailed
  • All tires replaced October 2009, lots of tread left and all in very good shape
  • Dual power windows
  • Dual heated power mirrors
  • Dual fender mirrors
  • Full Volvo fairings
  • Block Heater
  • 3 horns -- Volvo electric, Volvo air, Aftermarket trains
  • 32,000-lb (7,500-lb pin weight) TrailerSaver air-ride hitch w/factory cover + under-dash gauge/controller
  • Jackalopee trailer light converter (mounted under bunk -- safe & dry) w/commercial grade trailer connections
  • Audiovox hardwired camera w/3 channels -- 2 cameras on truck: one on hitch (use as rear-view when bobtail & as aid for hitching) and one on top-right rear corner of drom (use for right-hand merging). Third camera is on rear of trailer. Monitor mounted at top center of windshield, where a car’s rearview mirror goes
  • Pressure Pro tire pressure monitoring system -- in-dash w/repeater (both hardwired) + sending units on all 12 wheels
  • Tripp-Lite APS1250 inverter/charger (2500 watts peak) w/dash-mounted controller + Shore power w/surge protector + 2 wall-mounted 120V outlet strips in sleeper
  • Cobra in-dash CB w/NOAA weather channels
  • Panasonic AM/FM CD player
  • Garmin Nuvi 465 -- trucker’s model w/updates
  • Tekonsha brake controller, mounted under dash
  • Two hand-held fire extinguishers (one mounted on each seat base in quick-release brackets)
  • Seats professionally rebuilt (2005) & in great shape -- 9-way adjustable driver’s seat w/arm rest + 5-way adjustable passenger seat
  • Tilt & telescoping steering wheel
  • Cold A/C
  • Full-floor carpets
  • Twin Volvo bunks w/safety harness for each
  • Full curtains -- both full windshield & sleeper only
  • Sleeper A/C-Heater separate from driver’s
  • Original Volvo chest of drawers + refrigerator, microwave & porta-potty in sleeper
  • Writing/computer desk fits across sleeper -- sit on lower bunk & work at desk
  • Heavy-duty battery cut-off switch installed alongside batteries
  • Deck is ½” steel w/ heavy-duty polypropylene fenders from Fleet Engineers
  • Large Drom Box (80”w x 70”h x 24”d = 78 cubic feet) + full catwalk w/original Volvo steps & grab-rails for safety
  • Four tie-down rings on deck
  • Large 94-quart marine-grade Igloo cooler w/ mounting cleats on deck -- great for camping or just grocery shopping
  • All service records since purchase, including:
  • 2014 Full service LOF
  • 2013 Full service LOF + Preventive maintenance:
    • Cab air bags, shocks valves, etc replaced
    • Cam position sensor replaced
    • Fuel solenoid replaced
    • Clutch master & slave cylinders replaced
  • 2012 Full service LOF + Preventive maintenance:
    • Front brake diaphragms replaced
    • Brake air valve replaced
    • Doors to overhead cabinets in cab replaced
  • 2011 Full service LOF + Preventive maintenance:
    • Air governor replaced
    • Air dryer replaced
    • 3 new batteries
  • 2010 Full service LOF + Preventive maintenance:
    • Rear axle leveling valve replaced
    • Hood spring & shocks replaced
    • Radiator water-level sensor replaced
  • 2009 Full service LOF + Preventive maintenance:
    • Drag link replaced w/complete front-end check
    • Wheel alignment
    • HVAC blower motor replaced
  • 2008 Full service LOF + preventive maintenance:
    • Overhead performed
  • 2007 Full service LOF + Preventive maintenance:
    • Replaced all sensors on transmission
    • Full brake job -- front & rear
    • Replaced shock absorbers -- front & rear
  • 2006 Full service LOF -- Preventive maintenance:
    • Sleeper A/C line replaced
    • Drom Box installed
  • Recent full service -- always well maintained -- truck is ready to go
  • Titled as a Motorhome
  • Located in Raleigh, NC, near major airport (RDU)
  • Delivery and/or driving lessons available
For reference see:
http://rvhaulers.ca/wp_car_dealer/1999-volvo-610-casper-with-rear-deck/
https://docs.google.com/document/d/1qrsiB7Z087C5RYK47q73SXoHz1QDkSfoAQ0rHgAI6aA/edit?pli=1
http://www.hdtrvwhitelightning.com/
I agree with Jim & Wanda, Nice rig and my compliments on a very detailed add and great pics too. This is exactly the kind of combination I hope to find when my finances allow (and your close, I'm in central VA). I am really attracted to the short 610 (and 630 setups) it would work well with the places I travel with my horse trailer now, and I think would work just as well for me later when we move to a 5’ver and need to get around once the trailer is setup somewhere.
Good luck on your sale!
John
This is a very nice setup at a very good price. It should not last long.
This is exactly how an advertisement should be done to be successful.
The truck is ideally set up to be a daily driver. My 610 was the same wheelbase and it excelled as a daily driver. I loved it. It was so easy to take anywhere I wanted to go. Maneuvered far better than any pickup. All the "common" maintenance items have been done on this truck.
This is a very good deal if it meets your needs.....
  • 3 weeks later...
RV Cable Grip
Country Thunder Iowa
Nomad Internet
RV Air.
