LindaH Posted March 10, 2015 Report Share Posted March 10, 2015 By the way, I believe it is a DOT requirement that portable propane bottles be filled on a scale to avoid over filling in case the OPD malfunctions. If that's the case, then there are a LOT of propane dispensers who are filling tanks illegally! The only place we've had our portable propane tanks filled by weight was in New Mexico...every place else we've traveled and had portable tanks filled, they've always done it by gallons. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
The Quiet Assassin Posted March 10, 2015 Report Share Posted March 10, 2015 Being a cruising sailor I have had to find people to fill my UK style tanks all over the world. Venezuela was my favourite story. I took the tank in and the propane guy ran through his adaptors without success. By sign language he told me to come back tomorrow. I duly turned up next day to be told 'momento'. He marched over to the fish freezer, removed my tank and another larger one. Putting down his cheroot, he removed the valves from both tanks and just poured the liquid propane into my tank. He screwed the valves back on and resumed smoking. There was a safety check. He drew hard on the cheroot and waved it around the valve muttering something like ' no incendie'. FT since September 2007 Safari Trek + M/C http://johncarolandcharro.blogspot.com/ Link to comment Share on other sites More sharing options...
chirakawa Posted March 10, 2015 Report Share Posted March 10, 2015 The proper way to fill a portable tank is by weight. On the tank should be the letters TW (tare weight) followed by the actual weight of the empty tank. A typical 30 lb. propane tank weighs about 24 lbs. empty. The attendant would then place the tank on a scale and add liquid propane until the weight reaches 54 lbs. (24 plus 30). In order to pump liquid propane into the empty tank, the attendant would normally open the bleeder valve to let gas escape. This is done with a screwdriver. When the tank fills up to the vent valve level, liquid propane will escape. This is how some attendants fill bottles without the use of a scale. The method of filling has nothing to do with how propane is priced. Propane is sold by the gallon, like other fuels. However, many propane vendors don't want to mess with metering every gallon out and calculating a separate price for each portable tank they fill, so they just put a set price on each tank of a certain size. That price is typically set by the volume of the tank and the price per gallon, for example a 30 lb. tank is 7 gallons times $3.00 per gallon or $21.00 for a tank of that size. http://www.propane101.com/propanecylinderfilling.htm Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Pat & Pete Posted March 10, 2015 Report Share Posted March 10, 2015 Being a cruising sailor I have had to find people to fill my UK style tanks all over the world. Venezuela was my favourite story. I took the tank in and the propane guy ran through his adaptors without success. By sign language he told me to come back tomorrow. I duly turned up next day to be told 'momento'. He marched over to the fish freezer, removed my tank and another larger one. Putting down his cheroot, he removed the valves from both tanks and just poured the liquid propane into my tank. He screwed the valves back on and resumed smoking. There was a safety check. He drew hard on the cheroot and waved it around the valve muttering something like ' no incendie'. Classic ... Thanks for the grin . Goes around , comes around . Link to comment Share on other sites More sharing options...
Dutch_12078 Posted March 10, 2015 Report Share Posted March 10, 2015 If filling by gallon always do it in the morning - the cooler the temperature the more propane molecules you can get into that tank. Barb The LP vendor near our cottage uses the same style temperature compensated pump that's used on the bulk delivery trucks. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
bigjim Posted March 10, 2015 Report Share Posted March 10, 2015 "If that's the case, then there are a LOT of propane dispensers who are filling tanks illegally!" At least in the past we would sometimes fill cylinders off the delivery trucks even though we were not supposed to. It was still metered off the truck by the gallon. At some point they put a stop to it. Some people may still do it but they are not supposed to. Back in them olden days when I worked there the 80% bleeder was a knurled knob and you had to be careful and quick to close it as the temprature of the exiting liquid could freeze burn you severely. By rights we should have used gloves but you know how guys and employees are sometimes. They were transitioning to the screwdriver type valve about the time I was leaving that job. Link to comment Share on other sites More sharing options...
richfaa Posted March 10, 2015 Report Share Posted March 10, 2015 We have it done both ways . Our Propane vendor at home does it by weight as stated above the empty and full weights are on the tank. Here in Florida we fill at Pilot/Fj and they do it by the gallon. When on the road it is usually Pilot/FJ. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
Fulltimer51 Posted March 10, 2015 Report Share Posted March 10, 2015 Keep in mind that every state has its own rules about filling Dot containers. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
Barbaraok Posted March 10, 2015 Report Share Posted March 10, 2015 And propane filling in each state can vary by city or county. In Casa Grande you can get your motorhome propane tank filled by propane company coming through the park. In Mesa, can't do that, as the fire marshall has ruled that the density of the parks is too great and MHs can not be filled in place (nor can tanks be filled in the park) but can only be filled at vendor's sites. Bottles can be set out to be picked up by vendors who then leave another bottle, but don't refill in the park. Barb Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
