MoonTimber Posted March 6, 2015 Report Share Posted March 6, 2015 Both of the roof vent lids on my "New to Me" 1991 Jamboree are cracked badly. The previous owner sealed them with gobs of tape, but I'd like to replace them. Are these a universal size? Can I buy any lid from Amazon and expect it to fit? Link to comment Share on other sites More sharing options...
DuffMan Posted March 6, 2015 Report Share Posted March 6, 2015 For ~$25 you can use a vent cover and leave existing cover open w/o worry about looks, cracks, rain etc. Link to comment Share on other sites More sharing options...
Yarome Posted March 6, 2015 Report Share Posted March 6, 2015 Yes. There are fairly standard sizes but the issue is the hinge. When replacing just the lids you have to make sure the hinge format will match up. Camco has a pretty full line-up. I would look HERE to get the model number you need, then shop around for the best deal. Link to comment Share on other sites More sharing options...
Jimalberta Posted March 6, 2015 Report Share Posted March 6, 2015 You can even get lids at Lowe's and Walmart. Just check the hinge as pointed out already. Link to comment Share on other sites More sharing options...
bigjim Posted March 6, 2015 Report Share Posted March 6, 2015 I would replace them but even if you do the vent covers mentioned by Duffman are a must for me. They have some that are slightly different and cheaper in that the "grill" area is not able to open. I have never had the kind that opens but I would try them if I ever replace one or get a new rig. I think I would be tempted to go with the ones that are "smoke" colored. Link to comment Share on other sites More sharing options...
Yarome Posted March 6, 2015 Report Share Posted March 6, 2015 I have the MaxAir II's that give really good air flow and can be opened for cleaning and vent seal maintenance. I would never go back to permanently mounted covers. I really like the translucent smoke covers as well. On bright sunny days they have a really nice "soft glow" lighting affect. Link to comment Share on other sites More sharing options...
bigjim Posted March 6, 2015 Report Share Posted March 6, 2015 I think the MaxAir would be the best choice and I am glad to hear the comment on the smoke colored translucent covers. Link to comment Share on other sites More sharing options...
mscans Posted March 7, 2015 Report Share Posted March 7, 2015 I used and like the Maxairll due to the larger opening. Used it with the Maxair fan, worked great. That cover allows you to leave the vent open all the time to keep it fresh inside. Link to comment Share on other sites More sharing options...
MoonTimber Posted March 7, 2015 Author Report Share Posted March 7, 2015 But don't you want to be able to close it if you're camping somewhere that gets cold? I saw those vent covers on Amazon and they seemed pretty inexpensive. I was thinking about getting a pair of those after I fixed the lids. I imagine if we're camping in California in March that we want to close those at night. So I guess that means I need to climb up there when I have a good weather forecast, remove a lid and bring it to Lowe's or Home Depot to see if the hinge matches up? Link to comment Share on other sites More sharing options...
Yarome Posted March 7, 2015 Report Share Posted March 7, 2015 But don't you want to be able to close it if you're camping somewhere that gets cold? I saw those vent covers on Amazon and they seemed pretty inexpensive. I was thinking about getting a pair of those after I fixed the lids. I imagine if we're camping in California in March that we want to close those at night. So I guess that means I need to climb up there when I have a good weather forecast, remove a lid and bring it to Lowe's or Home Depot to see if the hinge matches up? Yes. You're going to want to replace those lids, but generally you're vents will be open (and possibly a window cracked) to 'some' degree for ventilation and humidity control... even when it's cold out you're going to want some air exchange. Taking one with you would certainly be the easiest. You could always just loosely tape a trash bag over the uncovered vent if you are concerned about bad weather. One thing to consider when purchasing vent covers is the material they are made out of. Some of the less expensive covers will become brittle and crack. Decent vent covers are not at all a bad investment if you can afford a little better quality. As mentioned earlier.. covers that can flip open for cleaning are very desirable. Link to comment Share on other sites More sharing options...
bigjim Posted March 7, 2015 Report Share Posted March 7, 2015 I don't think you will find the covers at Lowes or Home Depot. Some Walmarts but most likely at a place that sell rv parts, sometimes a mobile home supply. Link to comment Share on other sites More sharing options...
TxCowboy Posted March 7, 2015 Report Share Posted March 7, 2015 I agree with Bigjim. RV dealers can get you the right vent lid and, once you know which on you need, it's easy to find a supplier. I replaced all three on my Heartland last year and got them on sale from my local RV place for about $15 each and installed them all in less than an hour. If you have the crank handle version, you'll need assistance from a friend inside the RV so you don't have to climb up and down from the roof. It just makes things go so much faster. I also agree with the previous comments about adding a vent cover over each of them. It is another inexpensive upgrade that provides great benefit. The vent covers are also much heavier plastic plus permit you to leave the vents open when traveling or during inclement weather. Link to comment Share on other sites More sharing options...
bigjim Posted March 7, 2015 Report Share Posted March 7, 2015 One of the best things about vent covers is they can keep you from screwing up by leaving the vent open and getting rain into the rv. When I first started the guy next to me left a vent open over his bed and took off on a 2 week trip without the trailer. Guess what he came back to. That convinced me. As soon as I was recuperated from my surgery I went to Camping World and bought some that I installed easily myself. Link to comment Share on other sites More sharing options...
Dutch_12078 Posted March 8, 2015 Report Share Posted March 8, 2015 Here's a couple of diagrams that may help you identify which replacement lid you need: Link to comment Share on other sites More sharing options...
mscans Posted March 8, 2015 Report Share Posted March 8, 2015 But don't you want to be able to close it if you're camping somewhere that gets cold? I saw those vent covers on Amazon and they seemed pretty inexpensive. I was thinking about getting a pair of those after I fixed the lids. I imagine if we're camping in California in March that we want to close those at night. So I guess that means I need to climb up there when I have a good weather forecast, remove a lid and bring it to Lowe's or Home Depot to see if the hinge matches up? The Maxair covers go OVER the usual cover that cranks up and down. it keeps the opening water free even during blowing rain. During cold weather of course close the crank up covers and consider an insulating pillow to put in the opening, Camco carries that, pretty cheap. The actual covers you get depend on the manufacturer as mentioned by others. (yes the hinge is usually the major difference and makes them easy to match). Once you have them identified they can be ordered for $10-$20 and are an easy replacement. the Camco covers will also protect them against hail and sun damage so that will be the last set you get to replace. The info that Dutch has on the hinge area is what I used when I matched my covers, it was right on! have fun. Link to comment Share on other sites More sharing options...
Phaeton10 Posted March 8, 2015 Report Share Posted March 8, 2015 http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1311.R2.TR2.TRC0.A0.H2.Xrv+vent+covers.TRS0&_nkw=rv+roof+vent+covers&ghostText=&_sacat=0 Link to comment Share on other sites More sharing options...
TxCowboy Posted March 8, 2015 Report Share Posted March 8, 2015 http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1311.R2.TR2.TRC0.A0.H2.Xrv+vent+covers.TRS0&_nkw=rv+roof+vent+covers&ghostText=&_sacat=0 I normally do Amazon but that is a very nice link too. Link to comment Share on other sites More sharing options...
MoonTimber Posted March 10, 2015 Author Report Share Posted March 10, 2015 I'll do eBay if the seller has a good feedback rating, but I think I'm going to stop in at camping world first. It might be helpful to pay a little more and be sure I'm getting the right hinge. I did find another diagram with really good hinge information on Amazon and thought I should post it. Look at the secondary picture on this item: http://www.amazon.com/Camco-40161-40168-Unbreakable-Polycarbonate/dp/B0006JLU1I/ref=sr_1_3?ie=UTF8&qid=1425790528&sr=8-3&keywords=rv+vent+lid Link to comment Share on other sites More sharing options...
Pat & Pete Posted March 10, 2015 Report Share Posted March 10, 2015 Link to comment Share on other sites More sharing options...
MoonTimber Posted March 17, 2015 Author Report Share Posted March 17, 2015 That's the picture Pat & Pete! Now you don't have to go to Amazon. Link to comment Share on other sites More sharing options...
MoonTimber Posted April 3, 2015 Author Report Share Posted April 3, 2015 My buddy climbed up on the roof and removed one so I'd be able to look at the hinge (as suggested here). The closest match I could find was 40160 from the Jenson ad above. It looks considerably different, but it's the right lid, so I thought I should post a few before and after pics in case someone else comes long someday looking for this information. Notice that the metal sliding bit on the original is angled, where the new one is straight and shorter. Also, the new hinge is metal and the original is plastic. There are instructions in the box, but to remove it you have to get that long thin rod out: Mine had a pair of screws holding the rod in at each end. The screws don't work on the new lid so I will have to think of something else before we go on a long trip. Perhaps a dab of glue. Once the screw is out of the way, I used a very thin screwdriver to tap it out one side. Link to comment Share on other sites More sharing options...
LFDR3116 Posted April 3, 2015 Report Share Posted April 3, 2015 As an addition to my husbands post, I would suggest the you get smoked or non-clear covers. We like the smoked. It does let in light, but helps with the bright sun and the heat you can get from overhead. When we replaced ours, we found that the newer ones are not the quality of the 15 yrs old ones that were original. Lighter weight materials. Link to comment Share on other sites More sharing options...
MoonTimber Posted April 5, 2015 Author Report Share Posted April 5, 2015 I wasn't sure about getting the smoked ones. That might have been nice. The ones I bought are "unbreakable polycarbonate". They are vastly superior to the ones that were on there, and they were only $4 more than the regular ones. The plastic is about twice as thick and very flexible. I'm only planning to keep this RV for one or two years so I don't think I'll be able to judge how well they hold up. I would expect that even junky ones would last longer than that. Link to comment Share on other sites More sharing options...
Kirk W Posted April 5, 2015 Report Share Posted April 5, 2015 The ones I bought are "unbreakable polycarbonate". Very good choice. They outlive the OEM ones and will survive much more hail. Another thing you may want to consider is one of the vent covers that allow use of the vents while traveling and prevent rain entry if left open, such as this one shown. There are several brands and you can get them from Amazon. Link to comment Share on other sites More sharing options...
MoonTimber Posted April 5, 2015 Author Report Share Posted April 5, 2015 Very good choice. They outlive the OEM ones and will survive much more hail. Another thing you may want to consider is one of the vent covers that allow use of the vents while traveling and prevent rain entry if left open, such as this one shown. There are several brands and you can get them from Amazon. I like your new avatar photo! I have a vent cover like that over my third vent lid - the bathroom vent. It's busted up too, so I ordered this Camco 40421 Aero-Flo Roof Vent Cover when I ordered those lids, I just haven't installed it yet: http://www.amazon.com/gp/product/B0006JLU22/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 I would have worked on it yesterday but my Father-in-Law came over and we fabricated a six foot high stairway for my kids outdoor play set. It's unexpectedly raining today so my wife and I threw a tarp over the RV. I need to seal the roof. Link to comment Share on other sites More sharing options...
