Sold - ONAN 5.5 KW QUIET DIESEL RV GENERATOR IN ALUMINUM DIAMOND PLATE ENCLOSURE
Matt20874
For sale is an Onan 5.5 KW Quiet Diesel generator and custom built, aluminum diamond plate, enclosure. This is a very quiet generator and meets National Park standards for in park use. This is set up to be installed in the back of your diesel pick-up. Included in this sale are custom battery cables that run from the engine batteries to the generator. (Originally set up for an F350 crew cab) Also included in this sale is a Transfer Flow fuel filler neck that allows the generator to draw diesel from the truck tank. The dip tube is cut to a length so that it will leave you with at least 11 gallons in the truck tank for an F350. Other things included are an optional remote start kit utilizing a key fob. This was never installed but shouldn't take much work. The oil, oil filter and fuel filter were changed this past fall and have zero hours on them.
This sale is for major components as described above and seen in the pictures. You will have to provide miscellaneous parts, accessories and know how. For the mechanically inclined this is a very "doable" project with the possible the exception of installing the fuel filler neck. If you are not mechanically inclined you will need to have a professional install it for you.
Other features:
1. Tool box is lined with insulation to further reduce sound.
2. The louvers in the tool box are aluminum with bug screens installed.
3. Tool box lids have gas springs and locks.
4. Lifting bar included.
5. Onan operators manual, Onan installation manual, Onan parts catalog and Transfer Flow installation instructions included.
This generator produce 5500 peak watts at 60hz, 240V / 120V single phase.
1 - 240V / 45.8 amp receptacle.
1 - 120V / 30 amp receptacle.
1 - 120V / 20 amp receptacle.
This was installed in my parents tow vehicle which they had to sell due to health reasons.
Asking $6800 obo
Please let me know if you have any questions.
  • 1 month later...
Kerry,
The enclosure is 61" wide x 28" deep x 23" tall at its tallest point. Weight of generator, enclosure, battery cables, etc.. is around 450 lbs.
I should also add the diesel engine is a water cooled Kubota. Very nice.
Thanks
Matt
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
RV Cable Grip
Country Thunder Iowa
Nomad Internet
RV Air.
