Big Z Posted January 27, 2015 Report Share Posted January 27, 2015 All the brake pads look to be over an inch wide! (fwiw) My concern is how touchy the system is!... I have probably less than 1/2 an inch stroke of pedal, (feels like a 1/4") from touching the pedal to max -- Lock um up!-- position! ... Could it be a bad valve? ... is there any adjustments? I'm sure I'll be taking the Freightliner M2 in for a check up before leaving AZ, but thought I'd ask you experienced MD & HDT drivers here first! Thanks! Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 27, 2015 Report Share Posted January 27, 2015 Sounds right. I've never measured, but probably have 3/4" of travel. All the braking happens at the bottom, based on watching the brake pressure gauge, What I mean, is, that the gauge will barely move for most of the initial pedal travel. as this is when the slack is being taken up. Keep an eye on the pressure gauge, as you apply the brakes. You'll get the feel for it. Link to comment Share on other sites More sharing options...
porky69 Posted January 27, 2015 Report Share Posted January 27, 2015 If the brakes(slack adjusters) are setup too tight you could have overly touchy brakes. If you know how to adjust them, crawl underneath and back them off 1/8 of a turn(moves the shoes just slightly away from the drums). If you are not positive what you are doing take it to someone who does. Link to comment Share on other sites More sharing options...
Big Z Posted January 28, 2015 Author Report Share Posted January 28, 2015 If the brakes(slack adjusters) are setup too tight you could have overly touchy brakes. If you know how to adjust them, crawl underneath and back them off 1/8 of a turn(moves the shoes just slightly away from the drums). If you are not positive what you are doing take it to someone who does. These are self adjusting brakes. Link to comment Share on other sites More sharing options...
Big Z Posted January 28, 2015 Author Report Share Posted January 28, 2015 Sounds right. I've never measured, but probably have 3/4" of travel. All the braking happens at the bottom, based on watching the brake pressure gauge, What I mean, is, that the gauge will barely move for most of the initial pedal travel. as this is when the slack is being taken up. Keep an eye on the pressure gauge, as you apply the brakes. You'll get the feel for it. Oh! I got the feel of it! LoL!... What little there is! Link to comment Share on other sites More sharing options...
