Just Don Posted January 25, 2015 Report Share Posted January 25, 2015 I'M having major electrical problems(maybe major to me) dryers acting up, frig is stop freezing unplug it it will start back up, at times our hot water heaters stops heating I have changed thermostats even though I have been told it's not the problem gas side works and furnace motor isn't working up to speed could be going out was told by electrician. I did have a surge protector during this time. While at Johnson Ingram, TX creek (Johnson Creek was not the park with the electrical problem) I bought a Progressive EMS-PT50C April 2014. Could the ac's be next? I have read this could affect the motors if it did in furnace are AC's next.We bought LG frig in March 2014 before going to this park with electrical problems(story is someone was leaving and didn't unhook) after this park SPLENDIDE washer/dryer shut down it would end up needing a new circuit board(that's was a ouch). I did tell owners they where unresponsive I heard the electrician say there was a problem we left, but to late. Are the two ac's next. I heard this could weaken motors.I have got electricians to check the pole in Chalk Hill, had him check electrical inside he's says it looks good and probably was indecent at park. Would it take this long for all this failure to start happening to electrical components?What can I do is there something I can look for? I actually don't trust RV techs in the area. I'M trying to cut my wife off at the pass of buying a DRV mobile suite doing this or thinking on it more. This is very frustrating with every thing plus father and mother dying in last two months.I don't want to buy another rig. I need to fix the problem.Yet it's tempting to walking away this. Good chance I used a wrong word here please forgive me and over look it please. 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 25, 2015 Report Share Posted January 25, 2015 To answer your question - yes, these things show up over time if you were running on low voltage or if you have electrical surges or the like, from damaged power equipment. You should be able to file under your insurance if you reported it initially. If you did not, then you are out of luck on that front. It could also be a low or bad battery or a bad converter on the 12 volt side. It is not clear from your descriptions what EXACTLY the issues are. But many RV appliances will not run properly unless they have the right 12 volt power. You really need to isolate one appliance at a time and debug it. That way you will find immediately if you have a current power problem with 12 volt or 120 volt. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Mastercraft Posted January 25, 2015 Report Share Posted January 25, 2015 Electrical problems are no fun when you are on the road, but the good thing is there is no magic involved to isolate the problem. The furnace fan mentioned, if you have a typical RV furnace, the motor is 12v. If your battery charging system is keeping the batteries at 13.8v ish and the furnace seems to be running slow, check the 12V at the furnace with a hand held voltmeter. If it is in the 13V range when you are on shore power, maybe a fan motor issue. If you have two furnaces, are they both running slow? Your dyer....is it 120 or 240V? If its 240v, a FUBAR park power system would be hard pressed to damage it. If it was missing (open) half of the duplex , it wouldn't run, if the neutral was floating, it wouldn't care. The non electrical storm related "surge" thing I think is a bit of a myth. The utility company prides itself in providing 120/240 within about 2% at the meter. A FUBAR park system with a loose or spongy neutral could give you what appears like a surge on one leg of the 120v and a brown out on the other leg. Neither situation is good for the coach loads. RVs are subject to this situation since the ground and neutral aren't connected in the coach electrical panel like they are in a residential and commercial electrical panels. The Progressive EMS-PT50C ...... could it be kicking the power feed to your coach off on line noise, leaving the battery bank to run low (furnace fan issue), dumping the fridge so a human has to put it in "ON" mode again. 2009 Volvo 780 D16 535hp 1850 ft-lbs I shift 3.36 Thermo King Tripac APU DIY Bed and Frame Extension ET Hitch, Stellar EC2000, EcoGen 6K 2002 F350 CC Dually w/ Lance 1181 2012 Mini Cooper S 2007 Teton Royal Freedom " The only place you will find success before work is the dictionary " Link to comment Share on other sites More sharing options...
Just Don Posted January 26, 2015 Author Report Share Posted January 26, 2015 Thanks every one for your help with your answers. I was hoping to understand more about the problem I seem to have and y'all have helped a lot. I planning on getting a rv tech to check it out for me. Maybe he can find solution to problem and fix it. I do have LG frig it don't run off batteries. Thanks every one for your info. 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
Wrknrvr Posted January 26, 2015 Report Share Posted January 26, 2015 This is some simple things to do for your situation. Plug your fridge into the power post with a electric cord directly. That will eliminate anything in your system until you figure it out. Next would be to check your batteries connections and then turn off your converter and use a battery charger set at about 10 amps. You do need a AC/DC volt and amp meter. if you do not have a meter with DC amp capability you need to purchase one for diagnosing your problems. Home Depot and Lowes have a AC/DC volt-amp meter for about 75 bucks. They are not on the professional level but will give a good idea as to what is happening. It has to have DC amp capability. Also you need to have a simple DC meter to test for DC voltage at the same time you are checking amperage . With both meters connected you can see what volts things area operating at and what amperage it is operating on at the same time.. Now with the meter we can discuss what is really happening in your system. with this meter we can communicate with you as to what it is suppose to do and what I is doing. Then we can separate out each issue and solve your problems. Safe Travels, Vern Link to comment Share on other sites More sharing options...
Just Don Posted January 29, 2015 Author Report Share Posted January 29, 2015 Thanks every did find a problem some loose lugs in breaker and 50amp cord. So heading in the correct way. 2012 Nuwa Champgne 38CKRD 2012 Dodge Laramie 3500 Full timing since 11/20/2012 Link to comment Share on other sites More sharing options...
