Tucsontech Posted December 17, 2014 Report Posted December 17, 2014 We have a 2003 Jayco Greyhawk 26 SS (class C) that we bought new. We have had an unusual scenario at times which I can't figure out yet. The coach door on a hot day, especially if the sun has been beating on it, refuses to open. It creates a situation where we have to enter and exit through the cab doors and could be a safety concern in an emergency. We have tried to open it from inside and out and even while banging on it. Finally if in the shade or tempeture drops it will open and work normally. The locking mechanisms work freely and I have tried oiling the rubber door gasket surfaces and even tried talcum powder on them. Has anybody had a problem like this? Would appreciate knowing what might be going on and how to remedy it.
rdickinson Posted December 17, 2014 Report Posted December 17, 2014 Is it a dark color? An RV repair facility told me dark colored units expand more than others.
Chad Heiser Posted December 17, 2014 Report Posted December 17, 2014 Most likely the door is expanding due to the heat and is getting wedged in the door frame. Does it happen when the awning is deployed or just when the door is in direct sun exposure? 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website
Kirk W Posted December 17, 2014 Report Posted December 17, 2014 I would test it by removing the door latch mechanism and then see if the door opens or not, as that way you will at least know which area is the problem. Does that problem happen suddenly or does it get difficult first, then slowly become worse? Does the latch seem to operate when the door is stuck? I must say that this is one I can't remember ever hearing of before. If you do find the cause of the problem, please do return and share the information with all of us. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure
gypsydan Posted December 17, 2014 Report Posted December 17, 2014 A thought. Was it built during the winter, in the north. As you know, metal can expand with heat. If it was built during a cold time, they may have built it with tolerances for cold weather.when the door was "shrunk" due to the cold. Then, when it gets warm it expands to a normal width and the tolerances shrink to freeze and enlarge the door within the frame. The frame, though, can't expand as much for it has the walls to push against, so it would stay at its normal width. Another aspect to think of: where does it get stuck? on the top, the bottom, on both sides, or just one side. 2009 Four Winds Chateau - 25' class C 2002 Chevy Tracker
rdickinson Posted December 17, 2014 Report Posted December 17, 2014 Can you tape some Tyvek Paper from Home Depot to the door. Use the door as a template and trim with a small Olfa knife. something white, paper a sheet, something to reflect the light. If it works a graphics firm could use a 3 M or other product to cover the door. Hopefully matching or complementing existing colors. It needn't be white, just something lighter than what you have now. I doubt being made in the Winter anywhere is a factor. The rig would have in a built in a climate controlled environment. I was told a very dark 40' trailer can expand as much as 2" in length. Have you contacted the manufacturer?
bigjim Posted December 17, 2014 Report Posted December 17, 2014 Can you see from the inside or outside the door margins? (the gap between the frame and the door itself) If you can you can look when it is cool and hot to compare the two. Has it opened with difficulty before it stops openning. If so you may find some scrap marks where it is sticking. If the margins are really close it may be really critical to be level. I have 2 doors on my travel trailer and have had a partial problem with the bedroom door sometimes and my rig is white. The spot where it happened I was in direct sun most of the day all the way to sunset. I just thought a couple of key spots to look are at the door corners and also the threshold. On the one I described it tended to catch at a corner first. I should have read gypsydans post first as I know this is mostly a repeat but may still be usefull.
dmcb Posted December 18, 2014 Report Posted December 18, 2014 I would leave the door ajar when you know it will be warm. Then carefully close it to see where the problem is. Doug
kathydavidb Posted December 18, 2014 Report Posted December 18, 2014 On a warm day you can also put white paper in the jamb of the MH and chalk or similar product on the door. Close it slowly & look for transfer in the area where it hits. Dave. 2006 Coachmen Aurora 36ft. Class A motor home. 2009 Honda CRV toad. "Snowbirds" apprx. 6 mos. each year. Travelling to the SW each winter than returning to Wi. each summer. Retired and enjoying our travels along with Buddy the cat.
oscarvan Posted December 27, 2014 Report Posted December 27, 2014 Kirk's suggestion is the best one. (As often.... ) Eliminate the door itself, or the lock. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/
skp51443 Posted December 27, 2014 Report Posted December 27, 2014 Remember the good old days when you'd always have a sheet or two of carbon paper handy? I haven't seen any for years aside from the stuff the dentist uses to polish fillings. First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime.
Carolo Posted June 21, 2015 Report Posted June 21, 2015 I am having the same problem with a door that will not open or close when the rig is in the intense sun light. Today, as suggested by Roger Dickinson, I tried hanging a sheet over the door and it worked. It was a hot 94 degrees here today. So now I am thinking maybe there is a heat resistant clear coat that could be sprayed or painted on top of the dark colored door. I will check out this possibility tomorrow,Monday. There may be no such thing for all I know. I don't know if Tucson tech solved his problem or not.
rdickinson Posted June 23, 2015 Report Posted June 23, 2015 Consider a graphics design firm. They can use a 3m vinyl to stick to and cover the door, Make sure they remove all trim, latches, handles door hold backs to the coach body. That way when installed it will be a cleaner fit needing less caulking. In the cabinet business and with corian, less caulk is better. I'm glad it worked for you. Cheers Roger
