Dale G Posted December 12, 2014 Report Share Posted December 12, 2014 Hi guys, Looking at buying a Newmar motorhome with a Cummins ism 450 with allison transmission. It is a 2007 model and has 150k plus miles on it. I would appreciate any opinions or actual experiences that you may have on this motor or transmission. Anything I should really look at? Link to comment Share on other sites More sharing options...
Jimalberta Posted December 13, 2014 Report Share Posted December 13, 2014 Nicely broken in. The ISM should have a 2 stage jake brake as standard which is very nice to have. This is a very good combination with the 6 speed Allison. Link to comment Share on other sites More sharing options...
Guest ticat900 Posted December 13, 2014 Report Share Posted December 13, 2014 Hi guys, Looking at buying a Newmar motorhome with a Cummins ism 450 with allison transmission. It is a 2007 model and has 150k plus miles on it. I would appreciate any opinions or actual experiences that you may have on this motor or transmission. Anything I should really look at? That unit is well used at 150K on a 2007 ? ISM450 is great engine and big torque . I have the ISL 425 motor and wished I had the ISM as the ISL is not powerfull enough loaded on mountain passes. you should be happy with the power of this motor the 150K mileage newmar you must be getting this unit for under 100K I assume? Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted December 13, 2014 Report Share Posted December 13, 2014 Dale- that engine is the newer version of the M-11 that is in the Volvo. Great engine and many road tractors have them. Good luck on the coach! Link to comment Share on other sites More sharing options...
Dale G Posted December 13, 2014 Author Report Share Posted December 13, 2014 Jim The only concern I have is that I believe it is a variation of the truck ISM because it is a special version for motorhomes. It only comes as 450 & 500hp models. The specs call for an overhead at 120,000mi. intervals. Wonder what they did to these for motorhome use because motorhomes are not usually known for high miles. Link to comment Share on other sites More sharing options...
Jimalberta Posted December 14, 2014 Report Share Posted December 14, 2014 Now if only we could get a ten speed automatic instead of a six speed..... Link to comment Share on other sites More sharing options...
