oscarvan Posted February 8, 2015 Report Share Posted February 8, 2015 I've had it POUR on my 2000's (not on purpose) and they were fine. I believe they are designed to handle that. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
rdickinson Posted February 8, 2015 Report Share Posted February 8, 2015 http://stopthesound.com/generator-soundproofing/soft-generator-cover/ Came across this. You would need air in and air/exhaust out. I would go with 2 layers with a space between and offset the holes so noise and air have to go around one or more corners. Link to comment Share on other sites More sharing options...
Yarome Posted February 8, 2015 Report Share Posted February 8, 2015 I've had it POUR on my 2000's (not on purpose) and they were fine. I believe they are designed to handle that. If you had them plugged in and running, you live a charmed life. I wouldn't try that again. Link to comment Share on other sites More sharing options...
Yarome Posted February 8, 2015 Report Share Posted February 8, 2015 We have a Honda 2000 and are thinking about buying a kiddie tent for it. We don't use it often but always worry if it rains while we are using it Looked into 1 man tents but seemed like any overkill than stumbled across a kiddie tent. Seems like a good solution.. A kiddie tent might be a little too enclosed for good ventilation and air supply. I have some folks using those portable shower stalls (or dunny) to protect their portables though. A much larger air volume and overhead ventilation, but I would still be concerned about the exhaust heating the material over a period of time. It seems like it wouldn't be that difficult to fashion an "umbrella" type setup that simply clamps onto the handle. Sounds like a good project. Link to comment Share on other sites More sharing options...
Ray,IN Posted February 12, 2015 Report Share Posted February 12, 2015 There is a company that builds such a toolbox/genset housing. Looks like adding your own sound-deadening insulation is demanded. On irv2.com a long time ago, a guy posted pictures and instructions how he built his own genset enclosure. The only thing I remember about that was, he used an automobile cooling fan for air circulation. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
ganto Posted February 20, 2015 Author Report Share Posted February 20, 2015 Getting back to the OP's question.. if you are just looking to protect the outlets from rain, you might take a look at the GenTent covers. Looks like for your genset it runs around $199 from the manufacturer, but it's a universal 10k gen cover.. so you can probably find one less expensive. well I apologize for not being here for a while. just have been busy. I seen the gen tents for my Honda. I got rid of the Honda and bought an aurora off grid version. since it's a liquid cooled system instead of an air cooled so it will take the beating if I wanna run it all night!! i'll be trying to think of a cover for it atleast the outlets Link to comment Share on other sites More sharing options...
