Price Reduced! 2012 STARCRAFT LEXION 354RTSA FIFTH WHEEL FOR SALE
Standard Features:
Kitchen:
3-burner range
12 cu. ft refrigerator
Backsplash in kitchen
Faucet with pull out sprayer
Solid Surface covers for sink
Solid surface kitchen countertops
Large picture window at dinette
Free standing table w/4 dining chairs
Oversized 21" oven
Range hood with light and exhaust fan
Sponge holder under sink
Storable cutting board
O
Construction:
1/2 plywood platforms for dinette and bed
5/8 plywood tongue and groove for main floor decking
2" x 3" longitudinal floor studs placed on 16" centers
Arctic Package
Screwed Stile cabinetry
Foil insulation in main floor and in slide out floors
Front fiberglass cap with integrated L.E.D hitch light
Gelled hi-gloss fiberglass sidewall exteriors
I-class cambered structural steel I-beam frame
Rear one piece fiberglass cap
Seamless one piece rubber roof
Crowned 5" roof
Tuff-Shell vacuum-bonded laminated sidewalls
Welded tubular aluminum floor
Exterior:
16" Radial tires
30" x 70" main entry door
ABS Fender skirt
Amber patio lights with inside switch
Exterior speakers, high output marine grade
frameless tinted safety glass windows
Front jacks with quick release pins
Galvanized steel wheel wells
Lockable baggage doors/insulated/radius cornered
Mor/ryde CRE3000axle equalizer
Nev-R-adjust brakes
Polished aluminum wheels
Prep for outside grill
Roof ladder
Slam Latches for pass through storage doors
Step light at entry door
Stor-galore basement storage
TV bracket in pass thru storage compartment
Interior:
6 panel residential style passage door
22" LCD HDTV in bedroom
40" LCD HDTV in living area
Ball bearing drawer guides
Battery disconnect switch
Ceiling fan
Crank-up antenna
Free standing end table
Halogen light
Hide-A -bed sofa/(air mattress)
Leather rocker recliners
Pleated day/night shades
Porcelain toilet w/foot flush
Prep for cable and Satellite TV
Roof mounted antenna for radio
Transom window w/wood trim above main slideout
Wood Plank vinyl flooring
Heat, Power and Electric:
Furnace
12V electrical system with deluxe 120V80AMP converter
50AMP power cord
120V GFCI protected exterior receptacle
A/C Chill grill
Battery box for two batteries
Black holding tank sprayer
Double 30 lb LP tanks on sliding tray
Outside shower
Uni-Dock utility center, heated and enclosed
Water heater by-pass system
Water system winterization kit
OPTIONS:
12 cu ft fridge
Generator Prep
King Bed
Mor/ryde pinbox
Partial paint Package
Customer Convenience Package which includes
12 gallon gas/electric DSI auto ignition water heater
15,000BTU A/C with louvered and directional ceiling vents
Electric Patio Awning
Deluxe pillow top mattress
Electric rear stabilizer jacks
Floor mounted safe
Foldable exterior grab handle
Microwave oven with carousel
Multi-media premium sound system AM/FM/CD/DVD w/mp3 and Ipod input jack
Northern Breeze bathroom power vent
Security lights (2)
Skylight in shower
Spare tire
Water purification system
3 Slides
11,375lbs. Unloaded Vehicle weight
2230 lbs Dry Hitch Weight
15,250 lbs GVWR
3875lbs Cargo Carrying Capacity
87 gal fresh water tank
85 gal Gray tank
50 gal Black tank
Wheel bearings repacked May 2014
Unit is winterized as of Oct 2014
ASKING: $42,000 http://s50.photobucket.com/user/pleasantpoint/slideshow/
  • 4 months later...
RV Cable Grip
Country Thunder Iowa
Nomad Internet
RV Air.
