Connecting electric cord to neighbors rv
maggie blair
It will not hurt either system as long as:
1. Your neighbor's RV has enough power to spare
2. You do not try to draw more power than the plug you plug into on the neighbor's RV will support. (If you are plugging into a regular outlet on the side of your neighbor's RV, it will only support 15 amps.)
My First Solar Install Thread
It will not hurt either system.
Dead on. Without knowing what size of generator your neighbor is running.. even though his rig may be 50amp.. that doesn't mean his generator is capable of putting out a full 50amps. Ie., you might only be sharing 30amps or less so I wouldn't run anything that I didn't have to while connected (water pump, fans, etc.) and would disconnect once your batteries are topped off just to be a good neighbor.
I know you don't really use much juice anyway so it shouldn't be an issue.
Easiest way in my mind to do it would to just plug in your charger or converter. You will then only be charging the batteries and wouldn't have power to the other A/C current devices you may have in your camper. No risk of accidentally turning on the microwave or coffee pot at the exact wrong moment. I have that ability, you may not.
Rod
2007 Honda GL 1800
The Gold Volvo is still running and being emptied in July.
I'd do it as Rod suggested....plug just your converter into the neighbor, if you can. If you have a converter integrated into your loadcenter you will not be able to do it this way, though. Many converters are wired such that they plug into a standard electric outlet, and these can be plugged directly into any electric source (like your neighbor). In your rig you likely have the combination, and that is hardwired into your system. But for others that encounter this issue, plugging JUST the converter into the neighbor (or into a garage 15 amp outlet) and just letting it charge the battery bank is a viable way to boondock, or moochdock (driveway boondock). You then run the necessary house systems off the inverter, and the converter charges the battery bank.
In your case, That will likely not be an option, but plugging in will not hurt your neighbor....follow the advice above. If you draw too much then HIS breaker will flip.
Living on the road since 2000
2022 New Horizons 43' 5er
2016 Itasca 27N 28' motorhome
www.jackdanmayer.com
