Sewer hoses on the ground
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
I don't know of listing for state requirements, but I have seen individual parks requiring it regardless of any state requirement. My take would be to simply follow the park's rules on it.
Dutch
2001 GBM Landau 34' Class A
Being on the ground is not really the issue - if it is on the ground it is flat - no flow to drain properly. What you should do is set the sewer hose on a slope from the rig to the drain so that it empties efficiently.
John
John
Titanium 29EX 29/34 Fifthwheel
I’ve stayed at a number of campgrounds that require it, but haven’t heard of any state code that requires it.  I think some state parks require it also but don’t know if that’s a state-wide requirement or just that state park system.
Interesting question, I never really thought about it since I always use a ladder system for my sewer hose.
It's not states that I'm aware of.... it's county and city ordinances.  It was required in Benson, AZ... don't know if that's still the case.
Full-timed for 16 Years
I hook up my sewer lines only when I need to empty. They last much longer that way and I have very large tanks so I can go over 2 weeks. Am contemplating an incinerating toilet and will be further able to lengthen the times between dump requirements. My first experience living in an RV in South Florida I had neighbor children who seemed to delight running over the hoses despite my politely informing their parents of the actions. "My kids would never do that. " was the response I got.
Rod
2007 Honda GL 1800
The Gold Volvo is still running and being emptied in July.
I think I have stayed at 1 campground in the past 5 years full timing that required me to do that. Not sure what the thinking behind it is, but if those are the rules then that is what will be done. As stated I believe it is a campgrounds rule not city or state rules.
2016 Mobile Suites 38RSB3
Lots of towns in Arizona (and maybe some counties) require that.   It allows anyone to see small seepage from the bottom of the hose which could happen because it is against desert landscape in most cases.   We have always used supports to gently slope the hose to the drain for better movement of fluids.
Barb & Dave O'Keeffe
SPK# 90761 FMCA #F337834
The sewer hose connection for our Beaver is below the basement floor and it is exceedingly difficult to maintain a slope to a drain, particularly if it is placed above ground level as many of them are.   I do the best I can but many sewer hose supports are taller than the height of my sewer output, especially when I've dumped the airbags.
Sandie & Joel
WiFiRanger Ambassador
I never left a sewer hose out. Hooked it up, did the dump and rinse, put it away. That said I did have to sometimes walk the hose lifting it as I went to get everything to flow. There's one casino where the dump is a standpipe on a concrete island; I refused to use that one. Hmmm. I wonder if that's why they placed it there?
Linda
I am full time and usually stay in the same site for a month or two. I almost always use the hose support to keep the hose off the ground and prevent damage to the hose. I have had rocks or thorns puncture a small pin hole which is undetected until the next flush and then you get an old faithful effect. If I am only staying a couple of days I sometimes don’t use the hose support.
2015 Itasca Ellipse 42QD
2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition
2021 Harley Street Glide Special
Fulltimer
Linda
That would not be practical for us. Our Teton washing maching drain bypass the gray tank. Goes to discharge.
4 hours ago, hemsteadc said:
x2.  It's not a great idea to leave your valves open, especially black.
What problems do you see with leaving the grey valve open for extended periods? We're often in one spot for a couple of weeks to a few months and have never had a problem with leaving the grey valve open. I do close it periodically to build up a supply for back flushing the black tank and flushing the sewer hose after dumping when needed.
Dutch
I do the very same thing. There is one additional thing that I have learned from experience. I keep the sewer hose on one of the sloping stands for them but I also put a U into it at the entry to the sewer system to form a hydraulic plug like a P-trap in plumbing. It stops odors and bugs from entering the RV waste tanks.
We are usually on private land but we leave the grey water open except a couple of times a month I will close it for a couple of days to help keep the tank bottom washed.  Where we are at now it is very dry and private land so we just let the grey go onto the ground.
Randy
I used to leave the grey open but now that my level indicators are not reliable I keep the grey closed. When the shower won’t drain I know it’s time to dump and flush.
Fulltimer
Yep, I do the same thing, Kirk. Works great...
Dutch
2 minutes ago, GlennWest said:
I have not done this with the Teton. Never had an odor.
Some systems seem to push air back up for some reason, but nearly all of them harbor sewer flies or similar creatures. If sewer flies get started breeding inside of your tanks you will probably get more cautious. I only had that experience one time and got more careful, either keeping both valves shut or use the trap.
