Battery replacement connection
ms60ocb
What is the extra Hardware/connections on top the batteries.
I have a 2015 Freightliner M2 106 that is past due for replacement batteries. I never paid much attention to  the top of the batteries because out of site, out of mind. It there a connection diagram? what is the extra connection? Personally I'm not able to physically handle hardware of that size . The local truck shop will get the work so I'm not sure if this will be as strange to them as I.
Clay
Clay & Marcie Too old to play in the snow
Diesel pusher and previously 2 FW and small Class C
I'm more interested in the extra hardware. I can't read anything off the device, is it resistive, a diode, fuse or?? The truck engine is a Cummins ISL 8.9 which could also be in a coach.
folivier  -  I do like like to use colored  used ty-wraps.
Clay
This picture shows the little enclosure box in question. I have no idea what is inside. I may have cut about 1/4 of the little enclosure off is downsizing. The terminal at the left edge of the photo is the Pos terminal of the left hand battery and the right hand end of the little enclosure is near the Pos terminal of the right hand battery. Clay
  • 2 weeks later...
It was a hot day this week when the batteries was disconnected. The little box is to protect fuse. I didn't look at the size or what the cable feeds.. Someday without the sweat.
Thanks for comments  Clay
