jcussen Posted May 29, 2020 Report Share Posted May 29, 2020 I am running 8 gauge from each bank to inverter and it is well within specs. Quote Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
GlennWest Posted May 29, 2020 Author Report Share Posted May 29, 2020 (edited) 23 minutes ago, jcussen said: I am running 8 gauge from each bank to inverter and it is well within specs. Magnum calls for 2/0 to inverters. I was looking at backing plates by magnum. The mini panel backing plate looks interesting. Less than $80.00. Boilt it to a piece of plywood and mount inverter. Actually, I could mount it to backing plywood wall with that plate. My bussbars are up there now but I going to remove them. With the E Panel they aren't needed. Edited May 29, 2020 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jcussen Posted May 29, 2020 Report Share Posted May 29, 2020 26 minutes ago, GlennWest said: Magnum calls for 2/0 to inverters. I was looking at backing plates by magnum. The mini panel backing plate looks interesting. Less than $80.00. Boilt it to a piece of plywood and mount inverter. Glen, like you, I have 3 packs, each limited to 20 amps by the BMS. If you look at a wiring size calculator, you will find even 8 gauge is overkill. Magnum is assuming one big battery, we are using 3. .http://wiresizecalculator.net/ Quote Foretravel 40ft tag 500hp Cummins ISM 1455 watts on the roof, 600 a/h's lithium in the basement. Link to comment Share on other sites More sharing options...
GlennWest Posted May 29, 2020 Author Report Share Posted May 29, 2020 My bms is 100 amp per each pack. Should never see over 30 amps to each set. I just finished removing my bussbars. They just took up to much room. Ran 2/0 cables joining together my battery pack. Yes overkill but had plenty. Same on grounds. Mounted 175 amp mbl fuse at hot end where I come off to inverters. This opened up the wall above my batteries. Plywood wall I built. Can put inverter there and main inverter on E panel door. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted May 29, 2020 Author Report Share Posted May 29, 2020 Oh and I have some nice bussbars I no longer need if anyone interested Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
