time_traveler Posted April 5, 2020 Report Share Posted April 5, 2020 Looking to improve our cell coverage when we are using our 5iver. Thanks Mark Quote Link to comment Share on other sites More sharing options...
time_traveler Posted April 5, 2020 Author Report Share Posted April 5, 2020 Anyone familiar with weBoost 4G-X RV Quote Link to comment Share on other sites More sharing options...
Big Rick Posted April 5, 2020 Report Share Posted April 5, 2020 I use fusion2go 3.0 Quote Link to comment Share on other sites More sharing options...
pjstough Posted April 5, 2020 Report Share Posted April 5, 2020 Just now, time_traveler said: Anyone familiar with weBoost 4G-X RV I believe it is limited to a boost of up to 50dbm, but can be used while driving down the road. We have the Connect 4-G with has a boost of up to 65 dbm, but is made for stationary use only. The important think to remember is that there has to be at least some signal for the booster to boost. Quote 2005 Winnebago Voyage 38J Link to comment Share on other sites More sharing options...
time_traveler Posted April 5, 2020 Author Report Share Posted April 5, 2020 I think I would only be using it for stationary Quote Link to comment Share on other sites More sharing options...
pjstough Posted April 5, 2020 Report Share Posted April 5, 2020 Another thing we have noticed about the inside antenna that came with our system and that is your cellular device, whether it be a cell phone, or a "mifi" device, they needs to right on top of or very close to the inside antenna for best performance. Quote 2005 Winnebago Voyage 38J Link to comment Share on other sites More sharing options...
rynosback Posted April 6, 2020 Report Share Posted April 6, 2020 33 minutes ago, pjstough said: Another thing we have noticed about the inside antenna that came with our system and that is your cellular device, whether it be a cell phone, or a "mifi" device, they needs to right on top of or very close to the inside antenna for best performance. I heard that your device needs to be REALLY close to the inside antenna. I have been toying with it getting one, but so far I have been able to get a decent signal. Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
docj Posted April 6, 2020 Report Share Posted April 6, 2020 5 minutes ago, rynosback said: I heard that your device needs to be REALLY close to the inside antenna. I have been toying with it getting one, but so far I have been able to get a decent signal. If you're primarily using the amplifier for a data signal, rather than a voice call, then the distance between the antenna and your phone shouldn't be a big deal IMO. You're probably going to use the phone's wifi hotspot or you're going to USB-tether it to a router so you, yourself, don't need to be near where it is. Even if you do want to make a voice call just use it in speakerphone mode or get a Bluetooth headset. Quote Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
rynosback Posted April 6, 2020 Report Share Posted April 6, 2020 All good points Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
Dapperdan Posted April 6, 2020 Report Share Posted April 6, 2020 We have one, it works as advertised. My experience has been, your hot spot or your phone does need to be close to the indoor antenna but you od get the signal boost! I like mine, we have the unit you're looking at. Dan Quote Link to comment Share on other sites More sharing options...
pjstough Posted April 6, 2020 Report Share Posted April 6, 2020 20 minutes ago, Dapperdan said: We have one, it works as advertised. My experience has been, your hot spot or your phone does need to be close to the indoor antenna but you od get the signal boost! I like mine, we have the unit you're looking at. Dan What make and model do you have? Quote 2005 Winnebago Voyage 38J Link to comment Share on other sites More sharing options...
time_traveler Posted April 6, 2020 Author Report Share Posted April 6, 2020 Thanks for the good info Quote Link to comment Share on other sites More sharing options...
time_traveler Posted April 6, 2020 Author Report Share Posted April 6, 2020 WeBoost Drive 4G-X RV (470410) $495 Amazon Quote Link to comment Share on other sites More sharing options...
Dapperdan Posted April 6, 2020 Report Share Posted April 6, 2020 We have the We Boost Connect RV 65 471203. Keep in mind you're going to have to have your hotspot or cell phone fairly close to the inside antenna, by that I mean within a couple of feet. It works great for boosting a cell signal as long as you understand how it operates. I also have a signal finder app on my phone so I know which direction to point the outside antenna. The RV 65 has a DIRECTIONAL antenna, to achieve the best results you'll want to know which direction your cell signal is coming from! Dan Quote Link to comment Share on other sites More sharing options...
filthy-beast Posted April 6, 2020 Report Share Posted April 6, 2020 These reviews might be helpful. https://www.rvmobileinternet.com/gear/mobile-cellular-boosters/ Quote 2020 Platinum F350 6.7L CC DRW, 2021 Riverstone Legacy 37mre 5th wheel Link to comment Share on other sites More sharing options...
time_traveler Posted April 6, 2020 Author Report Share Posted April 6, 2020 thanks Quote Link to comment Share on other sites More sharing options...
time_traveler Posted April 6, 2020 Author Report Share Posted April 6, 2020 I have heard good things about the SolidRF RV Pro kit Quote Link to comment Share on other sites More sharing options...
CincyGus Posted April 7, 2020 Report Share Posted April 7, 2020 If you're looking for just a cell booster, You have plenty of good advice and options here. If you're looking to share data with it, here is a link to an article I found very helpful. https://www.irv2.com/forums/f53/40-month-unlimited-internet-interested-442091.html Quote I've never seen a tombstone that said "He was a great employee". Be one but be an even greater husband, father, friend and person. That's whats important. Link to comment Share on other sites More sharing options...
time_traveler Posted May 17, 2020 Author Report Share Posted May 17, 2020 thanks Quote Link to comment Share on other sites More sharing options...
Carlos Posted May 19, 2020 Report Share Posted May 19, 2020 I have the Weboost car kit, which is the same electronics as the RV kit with a different antenna. I got a free cell/wifi/GPS antenna from a friend and will add that some day. But so far it has worked great as is. I just stuck the car antenna on the trailer roof and ran the wires in the door. Quote Link to comment Share on other sites More sharing options...
rynosback Posted May 20, 2020 Report Share Posted May 20, 2020 I spoke with a guy that has the WeBoost Drive 4G-X RV model. He says it is 50/50. He said that sometimes it makes the signal weaker, makes voice calls worse and sometimes everything better. This guy works from the road and is very tech savvy. Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
DKRITTER Posted May 21, 2020 Report Share Posted May 21, 2020 On 5/19/2020 at 11:37 PM, rynosback said: I spoke with a guy that has the WeBoost Drive 4G-X RV model. He says it is 50/50. He said that sometimes it makes the signal weaker, makes voice calls worse and sometimes everything better. This guy works from the road and is very tech savvy. I've found that if you have a good signal w/o the booster and you turn on the booster it can degrade the performance, so if we don't need it we don't turn it on. On the other hand if we have a poor signal and turn it on it will improve the signal and performance. So the answer is ............... it depends Quote 2013 Newmar Dutchstar 4318 2019 F150 KR 4X4 BlueOx 10K Tow Bar Link to comment Share on other sites More sharing options...
Carlos Posted May 21, 2020 Report Share Posted May 21, 2020 I've never had the booster make a bad signal worse. It will definitely cause issues with a decent signal, and may make it worse. It should only be used when needed. We are totally dependent on the internet for our jobs, which is to manage servers, so basically we're connected 24/7. We notice when things work or don't. Quote Link to comment Share on other sites More sharing options...
rynosback Posted May 22, 2020 Report Share Posted May 22, 2020 I just found it weird that lets say a 3 bar signal, which is not that bad in my book. The the booster could degrade the signal instead of boosting it to 4 or 5 bars. At least that is how I logically think. Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
Carlos Posted May 22, 2020 Report Share Posted May 22, 2020 Yes, exactly. You only deploy the booster in super low signal situations. And then it really shines. Quote Link to comment Share on other sites More sharing options...
