Motorhome Fire Palms RV Resort Yuma, AZ.
bobsallyh
This is the main reason I bought and installed a Fridge Defend/ARP unit. It prevents the refrigerator boiler from getting hot enough to damage anything.
Edited by Ray,IN
And that is the primary reason that I took the advice of Mark Nemeth and put one on our RV refrigerator.
11 hours ago, fly2low said:
That's the main reason I went with a residential fridge
The top five causes of house fires: https://www.thesilverlining.com/westbendcares/blog/five-common-appliances-that-cause-house-fires
5 minutes ago, dirtyboots said:
Thanks for the link.  Seemed a simple purchase until I looked at all the different models.  Is the basic that fits any fridge good enough or do you really need all the extras?  Thanks.
The basic Fridge Defend is adequate, I included an optional blower type fan since my OEM fans have stopped running. The cost of the new fan was much less than the work involved in pulling the fridge from the opening, replacing fans and controller, then replacing the fridge in the opening.
After installation I had to reduce the fridge cold setting, milk and other liquids were freezing. That was caused by the additional fan on the tubing pipe.
Edited by Ray,IN
The ARP company owner, I forget his name, tried to persuade Dometic and Norcold to put the unit on all absorption  units they sell but was rejected.
His name is Paul Unmack. I have known Paul for several years. He has done several seminars at Escapades on how RV refrigerators work and how to troubleshoot one.
Thank you.
I recall reading about this last year when RV'ing but never got around to studying it.
WHY doesn't Dometic have such a device installed in every fridge and if not it seems that they should be held liable for each and every RV fire when there is an issue and a cure?
The answer is probably that they don't want to pay Paul for what he has developed. The same is true for Norcold. I have spoken with Paul about this and even observed a conversation that he had with a Dometic representative at an Escapade. Paul does hold a patent on his device and has offered it to both companies.
A temperature activated switch doesn't sound too complicated. Imagine that...lives at risk and they're bickering over money! Where's Jonas Salk when ya need him!
We had that unit installed in our 5th wheel 3 years ago at the MOC fall rally . It is not all that expensive considering the damage a fire can do.
It would not be, if that was all that the device was. In fact, the safety additions by both companies amount to little more than that and they sometimes help. The ARP-RV device is far more. It has a temperature sensor on the boiler and another on the tubing up above and it monitors and tracks both and keeps a record that the owner can step through and read is they wish to see what is happening. When installed the device is allowed to monitor for a period of refrigerator operation and then is custom adjusted to the normal operating temperatures of the particular refrigerator that it is installed on. The one that I have also conols a fan in he hot air exit from the top of the refrigerator, The fan operates as needed and fan speed is adjusted based upon the temperatures inside. When temperatures get too high it removes power from the refrigerator, much like it would if turned off.
If you are interested, follow the link to learn more about the device.  After a 40 year career in electronics, I was happy to pay for his device and would not operate an RV type refrigerator without one.
Edited by Kirk W
By RV type refrigerator so you mean an absorption one? I had a compressor one made for RVs and wonder if that needed a fire suppressor as well.
Linda
Thanks!
I found their web site which seems designed in 1990.... Impossible to figure out....
