If you want a Luxury Diesel Pusher, but do not want to deal with the break in period for over a year then you have found the coach you are looking for. This coach has had it all done; it has been back to the factory to have the “home-team techs” tune it to perfection, then recently more Thor techs have serviced it to be sure it is spot on.
The Freightliner and Cummins Techs have recently been through the coach and made adjustments and additions to make sure those aspects are also taken care of and up to par.
The full living area furniture including the drivers and passenger’s seats, theater seats, fold out couch and dinette have just been replaced with the new and improved upholstery material. Not just upholstery, but all of the furniture including the frames, cushioning, and everything has been replaced and not used since, so you do not have to deal with the flaking and other issues the original upholstery has been plagued with.
The fans in the three roof air conditioning units have been replaced so you do not have to worry about the problem they had with coming apart and shredding the internals.
The Aqua Hot is working like a charm, has been serviced as recommended from day one.
The 65,000 miles on the coach have concluded the break-in period of the engine. That, combined with the consistent maintenance along the way, and the recent full check-over by Freightliner and Cummins techs, you can drive to your hearts content with full confidence.
I could go over the many things that we have done to keep this coach running smoothly but to summarize- this coach is in truly turnkey status. All you need to do is move in and take off to your favorite destinations.
This is a one owner, non-smoking, well-loved and taken care of coach. Below are some of the specifications and information about the coach.
If you have questions please contact me.
Drivetrain: Freightliner XC-R Raised Rail Chassis ,Cummins ISL 8.9L Turbo Charged Engine with 450HP & 1250 lb.-ft. Torque. Easy up the hills, tows a Jeep without even knowing it is there. Engine brake is delightful, power is confidence inspiring, and it rides like a magic carpet.
6 Speed Allison MH-3000 Automatic push-button transmission with overdrive,
Towing capacity 10,000 lbs.,
Fuel capacity 150 gal. with insert locations on both sides of coach,
ZF Independent Front Suspension w/ 60 degree wheel cut, steering in tight spots is effortless.
Bright polished 22.5 inch aluminum wheels wrapped in Michelin Tires
Construction: Full-body paint with Gel-Coat sidewalls,
Automatic Leveling jacks w/ touchpad controls,
Side-hinged locking compartment doors w/ automatic locks,
Basement pass-through storage and one bay has Easy Slide tray,
Heated Basement and water tank
Fresh water capacity 91 gal., gray and black at 51 gal. each,
No propane necessary,
3 Slideouts
Awnings: Power Entry & Patio Awning with LED lighting, Main awning has wind sensor,Window awnings,Slide Room Topper awnings with Aluminum Covers
Keyless Entry System
Atlas Foundation provides an excellent foundation for the coach to be built upon.
Interior: Polished porcelain tile throughout,
Ceiling Ducted Whisper Air Central cooling system,
LED lighting throughout Decorative Ceiling treatment with Mood Lighting,
All cabinetry is solid wood with raised panel doors, high-gloss glaze, and Nickel finish hardware,
New Ultra-leather furniture Driver side sofa with air bed, Reclining theater seating with footrest, U-lounge dinette dining,
Central vacuum,
55” LED Smart HDTV in living room and 40” LED television in galley,
JBL Soundbar with bluetooth,
HD Satellite system and Blue-Ray player
Kitchen: 20 cu. ft. Stainless Residential refrigerator with in-door ice and water dispenser,
Electric induction cooktop,
1.9 cu. ft. Stainless convection oven,
Residential dishwasher,
Solid surface countertop
Bathroom(s): This coach has a half bath mid-ship of the coach allowing bedroom privacy to be maintained. Both toilets are porcelain with dual water level flushing mechanisms.
Each bathroom has a vanity with overhead lighting and under sink storage The rear bathroom comes equipped with an oversized FULL HEIGHT shower with glass door and seat
Bedroom: King Sized bed, Ceiling fan,
Large storage capabilities in both the bedroom and rear closet,
32” LED television for Master Bed viewing, Sony Blu-ray DVD Player in bedroom,
Residential stacked washer and dryer in bathroom with ducting for dryer to outdoors,
Day/night shades throughout coach,
40inch TV outside under the awning,
Asking $215,000
Pictures by email upon request. I cannot figure out how to load them here, space is limited it seems.
Edited by GuysDigDirt
Share this post
Link to post
RVAir The cleanest air in RVing!
AGS Now Hiring
RV Pet Safety
