Inside dully valve stem
Twotoes
I have a hard time airing up my inside dullys. I have a Class A on a Freightliner chassis with 22.5 tires. Was considering putting extenders on but don’t really want to add a place where they can leak air. Looking into longer valve stems. Loves tire shop said they can add longer valve stems for $40 each side but I have to provide the stems. Anyone have any recommendations for purchasing long valve stems for an inside dully tire, online or store front? Thanks in advance.
2015 Itasca Ellipse 42QD
2017 Jeep Wrangler Unlimited Rubicon Hard Rock Edition
2021 Harley Street Glide Special
Fulltimer
The 2" straight extensions on the page TexasPSDX linked to look like they have a center pin that opens the valve on the stock valve stem when you press on the end of the extension.  This eliminates any chance of a leak as the extension is only pressurized when you're actually using it.
I couldn't tell from the pictures if the 6" extension works the same way.
Edited by Lou Schneider
WHY are the valve stems pointed in on the outside tire and out on the inside one? Why not have both point out? I ask myself that question every time I check the tire pressures.
David Lininger, kb0zke
1993 Foretravel U300 40' (sold)
2022 Grand Design Reflection 315RLTS
So the wheels will be position independent. Using an appropriate truck tire gauge makes reading the pressures reasonably easy.
https://www.amazon.com/gp/product/B000CONUJM
Dutch
2001 GBM Landau 34' Class A
13 hours ago, Twotoes said:
Thanks, but as I said in my post, I don’t want to use extenders. I want to use a longer valve stem.
I bought a 6" metal extension at a local auto  supply store. It's only used when adding air is necessary; otherwise it is in my toolbox for the air compressor in the MH.
That is a pretty common problem with inside duals. On our class A's I did use extenders as I believed that tire pressures were something that should be checked every day of travel.  When I replaced the tires I had the new ones mounted in a truck shop that put custom shaped valve stems on both inside duals so that I didn't need the extenders any longer. If you have a tire pressure monitor system, that will keep you aware of any loss of tire pressure.
Thanks Dutch. I do have a truck tire pressure gage. The problem is that when I need to check or add add air I have to remove the TST monitor and it is difficult for me to do on the two inside dullys. And yes Kirk, when I hade new tires put on, at a semi truck tire shop, I asked them to put longer stems on but they were out of stock, so I am trying to do it now. Loves said they would do the labor but they need me to bring them the stems.
Fulltimer
Thanks Joe. I did check with another Loves location and was told the same thing. They will do the labor but don’t stock the park. You would think that a semi truck place would have the part!
Fulltimer
I agree, especially when they sell new tires and repair tires.
