griffinmike Posted January 31, 2020 Report Share Posted January 31, 2020 Should Shortbed Trucks Tow Fifth Wheels? Updated on March 15, 2011 rvguru more Contact Author Major Manufacturer Says No! I just finished previewing the Trailer Life towing guide for 2008 and it confirms something I have suspected for a long time. In the Chevy section, which also applies to GMC trucks, there are two disclaimer warnings that jump out at you concerning 1500 and 2500 series pickup trucks. I will quote,"Manufacturer's note: Shortbed models are not designed or intended to tow fifth-wheel trailers." That's a pretty strong stance that opens up a flood of questions like: Does this apply to past model year shortbed trucks? Does this apply to shortbed trucks made by Ford and Dodge and others? How about the heavier duty trucks? Don't they built slide mount hitchs just for shortbed trucks? If this is true,what's up with that!? How about bumper towing with a shortbed or short wheelbase? In any case I believe it is clear, towing a 5th wheel trailer with a shortbed truck is not a good idea. It never has been. Now it is official. The other manufacturer's note limits the kingpin weight to 15-25 percent of trailer weight. This is a tried and true guideline but further defined this year by adding an actual weight limit to the warning. For 1500 series its 1,500 ponds and for 2500 series, 3000 pounds. The weight of travel trailers is also limited to 13,000 pounds with weight distribution for the 2500 series. Yet another manufacturer's note defines shortbed as 69.3 inches, standard bed as 78.7 inches and longbed as 97.6 inches. We move on to the Dodge section and find a lot of hemming and hawing, kinda sorta maybe language that throws the final determination of what your dodge can tow into the laps of their dealers with all the reliability that can go along with that. It is almost like Dodge doesn't want your towing business. It is also here we learn their published kinda sorta numbers are based on a 150 driver only in the truck. This is something I first remember reading in a late 90's Ford specific towing guide that further limited fifth wheel towing to units that where only one third the height of the truck above the cab. Does anyone remember Ford towing commercials on TV? If you do, or don't, next time you see one, note the height of the trailer being towed. Then notice the gross disregard of this standard you can see everyday on our highways. Then notice that even the tractor trailer rigs have wind diverters that control the wind turbulence above the cab. Ford is the only American manufacturer who is geared up and aggressively after your towing business. They are one of the sponsors of the TL towing guide. When you get into the guide you will notice even Ford soft-pedals the shortbox towing issue by stating the hitch will fit provided it is specially designed for small box trucks then dumps the explanation onto the dealer/ manufacturer. All in all this is a good guide to get a hold of and read to learn the fundamentals of RV towing. It is available along with towing guides back through 1999 at this Trailer Life web address: http://www.trailerlife.com/output.cfm?id=42175 I have collected towing guides back through 1985 if you need information before 1999. Contact me at rvguru"at"gmail.com(replace"at" with @). As with most things RV, when it comes to trailer towing, it's RV buyer beware! When it is time to get serious, get specific towing data from the truck dealer for what the truck can do and from the RV dealer for what the trailer requires. Remember to read the fine print and where ever possible, actually weigh the units to verify your finding. Remember most specs for both trucks and trailers are for base units and widgets whirygigs and toys add to weights quoted. Please, in all cases tow safely and do not take chances. If you are close to the limits of things, upgrade! This is too important to monkey with and do not let predatory salesmen talk you into anything. Even if you want to believe it ( the my truck can tow anything bravado), and get emotionally involved, be well within specs, not on the edge. It's just too important not to do it safely! Enjoy RVing! It is a great lifestyle. Quote Wandering1 Link to comment Share on other sites More sharing options...
whj469 Posted February 1, 2020 Report Share Posted February 1, 2020 I don't tow my or any fiver that I have had over the years with a short bed pickup. I know some do and some use slider hitches but I think that the long bed tows better then a short bed. They are long but easy to drive Quote Link to comment Share on other sites More sharing options...
rickeieio Posted February 2, 2020 Report Share Posted February 2, 2020 From a physics standpoint, the bed has nothing to do with it. Weights and balances determines how it handles. Put the hitch in the wrong place, or overload the rear axle and you'll have issues, long or short bed. Put the fifth wheel too far forward or back on my Mack and it drives horribly Don't ask how I know...... Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
NDBirdman Posted February 2, 2020 Report Share Posted February 2, 2020 Weight placement, and wheelbase length has a big factor. I would never pull a 5th wheel with a short bed regular cab truck, an accident would happen. My truck is a short bed, but mega cab RAM. It has a long wheel base and does just fine. Quote 2002 Fifth Avenue RV (RIP) 2015 Ram 3500 Mega-cab DRW(38k miles), 6.7L Cummins Diesel, A668RFE, 3.73, 14,000 GVWR, 5,630 Payload, 27,300 GCWR, 18,460 Max Trailer Weight Rating(For Sale) , living in the frigid north, ND. Link to comment Share on other sites More sharing options...
Stepchild Posted February 2, 2020 Report Share Posted February 2, 2020 I have owned since new a 2006 F250 6.0, standard bed (6.5') to tow a 06 Cougar 281 fifth wheel. Had a Reese Elite (called a Signature series then) slider installed with a flush mount rail system, meaning bed is flat with hitch removed. I was aware of standard versus long bed when I purchased it. Bottom line is I like the look of the standard more than the long bed. Maybe not a great way to choose a truck but the truth. No issues with this truck/trailer but that may be more about towing within limits. Cougar is 10k and has been weighed within limits several times. I don't think the bed or the 166" WB has any bad handling characteristics. The Reese is a good hitch but has it's limits. It doesn't like sliding when on non level ground and few other cases. If I had to choose again I would look at a Superglide or something with a fixed rail system. I can go into details but don't want to hijack the thread for a hitch discussion. My opinion: Run the numbers then stay within limits and have a pro do the install. Quote Link to comment Share on other sites More sharing options...
mptjelgin Posted February 2, 2020 Report Share Posted February 2, 2020 Did anyone notice that the posted information refers to "previewing the 2008 towing guide" and was last updated on March 15, 2011. How does it now find its way onto the board in a January 2020 post? So very much has changed with tow vehicles in 12 years. I suppose that the overall message (buyer beware, know how to run the numbers) is still valid. Most of the folks I know with short-bed pickups have them on Crew Cab trucks, so they are hardly short-wheelbase trucks. As long as the numbers work and the appropriate hitch is chosen to assure you don't crunch the back of the cab in tight turns, I don't agree that correctly spec'd and set up short-bed models are not appropriate for towing fifth wheel trailers. Quote Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
Pappy Yokum Posted February 4, 2020 Report Share Posted February 4, 2020 On 2/2/2020 at 12:57 PM, mptjelgin said: Did anyone notice that the posted information refers to "previewing the 2008 towing guide" and was last updated on March 15, 2011. How does it now find its way onto the board in a January 2020 post? So very much has changed with tow vehicles in 12 years. I suppose that the overall message (buyer beware, know how to run the numbers) is still valid. Most of the folks I know with short-bed pickups have them on Crew Cab trucks, so they are hardly short-wheelbase trucks. As long as the numbers work and the appropriate hitch is chosen to assure you don't crunch the back of the cab in tight turns, I don't agree that correctly spec'd and set up short-bed models are not appropriate for towing fifth wheel trailers. Along with many others, I tow with a short bed pickup. I have towed my 5th with a short bed, SRW, 1T, QC, CTD, Dodge Ram since 2005. Yes, I do have a PullRite SG (slider) hitch. Tows great, no problems, no issues - and I have had a long bed previously. I would never go back to a long bed - but that's my preference. So, "griffinmike" - tow with whatever YOU prefer - and/or choose to believe. ~ Quote Link to comment Share on other sites More sharing options...
