Wrknrvr Posted January 13, 2020 Report Share Posted January 13, 2020 I have seen a fair amount of Atwood afmd model furnaces have problems operating properly. Right now at the North Ranch in Congress Az there are at least 4 of the furnaces that have problems. Another one was under warranty and I told the customer I would not work on it. I have heard of quite a few other ones not functioning properly also. If you google it you can see what I mean. Even tube it and you can see the water on the power board problem. So has anyone replaced the afmd unit with a Suburban furnace? Curious, Vern Quote Link to comment Share on other sites More sharing options...
GlennWest Posted January 13, 2020 Report Share Posted January 13, 2020 Wiring and plumbling propane should be basically the same. I would think the outside part for the ductwork would be different so that would be changed also. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Sehc Posted January 16, 2020 Report Share Posted January 16, 2020 (edited) I like my Suburban. It could replace a Atwood. Depending on the model Atwood it would be more or less work. But it would be work. Edited January 16, 2020 by Sehc Quote Link to comment Share on other sites More sharing options...
