GlennWest Posted December 28, 2019 Report Share Posted December 28, 2019 Was reading the Magnum PAE manual and it steates mounting positions. Vertical on a wall and flat on a ceiling. I would like to mount it on a wall but but with the bottom sideways. This would allow both inverters better use of area. Straight to buss bars with cables .Anyone ever mounted one like this? Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Itinerant1 Posted December 28, 2019 Report Share Posted December 28, 2019 The 3012 (3000w hybrid) shows it could be mounted on a vertical surface (wall) with the DC terminals to the right, but as you said the manual doesn't show this for the unit you're looking at using. I'm near 4 years now using it like this. Quote 2016 F350 DRW Supercab XLT 4x4 6.7 3:73LS 2010 Carriage Cameo 34CK3 1,280 watt solar Link to comment Share on other sites More sharing options...
GlennWest Posted December 28, 2019 Author Report Share Posted December 28, 2019 Thank you. Just needed to see it worked like this. Did some further research on line and was stated not to have cooling fins downward in case of fire or internal failure. internals melting would run out the bottom onto floor. Getting very crowded in there with that large battery pak and getting two inverters in there. They will fit just needing to be a little creative. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
hemsteadc Posted December 28, 2019 Report Share Posted December 28, 2019 (edited) I don't recall seeing an inverter mounted on a ceiling. Edited December 28, 2019 by hemsteadc Quote Link to comment Share on other sites More sharing options...
GlennWest Posted December 28, 2019 Author Report Share Posted December 28, 2019 (edited) Actually my factory mounted inverter, 2500, was mounted on the bottom of my ceiling in my storage are. upside down. I could mount one like that but would interfer with my getting my head in there. May need to though. My door opening not very large. Edited December 28, 2019 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
