GlennWest Posted December 27, 2019 Author Report Share Posted December 27, 2019 Thank guys. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Sehc Posted December 28, 2019 Report Share Posted December 28, 2019 Glenn. I don't have 48 volts or LiFePo battery. I have six golf cart battery. Configured as three 12 volt battery. I have three negative 2/0 cables to one side of my 500 amp shunt. The other side goes to a bus bar. I have had this set for two years with no problem. I do six month maintenance including inspection and measuring voltage drop at each connection. I had the same problem. I wanted another shunt, but not enough room. I use these; https://www.bluesea.com/products/2104/PowerBar_600A_BusBar_-_Four_3_8in-16_Studs There are smaller; https://www.bluesea.com/products/2303/Common_150A_BusBar_-_Four_1_4in-20_Studs Quote Link to comment Share on other sites More sharing options...
GlennWest Posted December 28, 2019 Author Report Share Posted December 28, 2019 I have a pair of those bussbars. They do take up right much room. That is why I didn't want to add a third. Thanks for letting me know you use 3 negatives to your shunt with no problems. That is what I will do. Do believe I will need two 2/0 cables off of that shunt to bussbar to suppert two 440 watt inverters though. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Westsailor Posted November 27, 2020 Report Share Posted November 27, 2020 Curious about shunts. Aside from different amperage ratings is there any difference between shunts from different battery monitor companies? Can I use a shunt from manufacturer 'A' with a digital display from manufacturer 'B'? Quote Link to comment Share on other sites More sharing options...
Chad Heiser Posted November 27, 2020 Report Share Posted November 27, 2020 12 minutes ago, Westsailor said: Curious about shunts. Aside from different amperage ratings is there any difference between shunts from different battery monitor companies? Can I use a shunt from manufacturer 'A' with a digital display from manufacturer 'B'? Not generally. Magnum and Victron come to mind specifically. You cannot interchange the shunt Magnum uses with a shunt Victron uses or vice versa. Magnum has a separate brain that connects to the shunt while Victron has a brain built into the shunt. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Kirk W Posted November 27, 2020 Report Share Posted November 27, 2020 38 minutes ago, Westsailor said: Can I use a shunt from manufacturer 'A' with a digital display from manufacturer 'B'? Welcome to the Escapee forums. The best answer is, maybe. Problem is that to know for sure you need data from the manufacturer that they don't usually supply and perhaps an engineering degree to then figure it out. To try it would be pretty risky as the wrong shunt might damage your display. There is no standard input to those displays. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Jaydrvr Posted November 27, 2020 Report Share Posted November 27, 2020 44 minutes ago, Westsailor said: Curious about shunts. Aside from different amperage ratings is there any difference between shunts from different battery monitor companies? Can I use a shunt from manufacturer 'A' with a digital display from manufacturer 'B'? One only needs to know the resistance of both shunts to know if they're interchangeable. The system simply measures the voltage drop across the known resistance to calculate the amperage. If the two shunts are of different resistances, you'll get an inaccurate interpretation of that data. Jay Quote Link to comment Share on other sites More sharing options...
