billr Posted December 18, 2019 Report Share Posted December 18, 2019 (edited) Just finished a conversion for a friend and doing another soon as they wanted to ditch Direct. Thought an update on this might help with future searches Was a fairly simple process. Call Winegard tech support and they walk you through checking the direct traveler and programming box to see if it’s possible. Verifying model antenna and software in box. Order new LMB arm with Harness and a new reflector. They will confirm the P/N req. The cost for their kits were $279 plus tax and shipping this was from Winegard The conversion was simple and had great instructions Final step was a little tricky with the way to program the box but was fine Found 110, 119, and 129 first time They kept it simple with a couple of Wallys setup and activated with Dish outdoor Pay as you go account. Did learn if activating two Wallys, each needs to be activated on the # 1 receiver cable then moved to other location as receiver 2. This link I found on a few searches here was very helpful. https://rvseniormoments.com/tech-docs/dish-tv-for-rvs/directv-to-dish-travler-conversions/ Edited December 18, 2019 by billr Quote Bill and Joan and 3 Collie pups 2001 Volvo VNL 770 "The Doghouse" Singled short, "ET" hItch VED12 465HP Gen 1 Autoshift 3.58 ratio 2005 Mobile Suite 38RL3 2011 Smart Passion loaded piggybacK Weigh-It Portable RV Scales http://www.weighitrv.com/ Link to comment Share on other sites More sharing options...
