GlennWest Posted December 8, 2019 Author Report Share Posted December 8, 2019 John, If we ever camp together, be my guest. You have been a great help with this project. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Dave Jones Posted May 2, 2020 Report Share Posted May 2, 2020 We have a Magnun Inverter in our Motorhome. I just put in all new batteries. The meter inside the RV where we check the inverter and turn it on now will not work. There i a constant green light, but the actual Inverter screen just has rows of dashes and does not work. I manually turned off the invester under the RV -- but am totally confused why that inside switch and screen no longer works. It is how I turn it on and off while camping. Can anyone give us an an idea how to fix it or what can be wrong? Quote Link to comment Share on other sites More sharing options...
Randyretired Posted May 2, 2020 Report Share Posted May 2, 2020 (edited) I have had inverters that quit after changing batteries and sometimes by removing all power, including disconnecting the batteries for an hour or more has resolved the problem. Make sure the switches are off and connect the batteries before any other power if it is also a charger. Maybe this might work. If there is a converter that needs to be disconnected too. Edited May 2, 2020 by Randyretired Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
lockmup68 Posted May 12, 2020 Report Share Posted May 12, 2020 On 5/2/2020 at 1:19 PM, Dave Jones said: We have a Magnun Inverter in our Motorhome. I just put in all new batteries. The meter inside the RV where we check the inverter and turn it on now will not work. There i a constant green light, but the actual Inverter screen just has rows of dashes and does not work. I manually turned off the invester under the RV -- but am totally confused why that inside switch and screen no longer works. It is how I turn it on and off while camping. Can anyone give us an an idea how to fix it or what can be wrong? what did Magnum say when you called support? Quote 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
