Ladydane Posted December 4, 2019 Report Share Posted December 4, 2019 new to RVing and my discharge line seals are beginning to malfunction. How do I change them out Quote Link to comment Share on other sites More sharing options...
Kirk W Posted December 4, 2019 Report Share Posted December 4, 2019 Welcome to the Escapee forums. I am not sure exactly what you are asking about. Are you dealing with a leak from your waste tank dump valves? More information will probably help us to give you good advice? The dump valves for your waste tanks are removable and you can replace them fairly easily as long as you have reasonably good access to them. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ladydane Posted December 5, 2019 Author Report Share Posted December 5, 2019 My dump valve seals are not contained and are beginning to not close properly Quote Link to comment Share on other sites More sharing options...
agesilaus Posted December 6, 2019 Report Share Posted December 6, 2019 (edited) Unless they are different from all the ones I've seen they do not have seals. Not like you imagine anyway. They may get crud built up on the valve disk which keeps them from closing all the way. There are two solutions, very thoroughly flush the tanks. Wear rubber gloves, remove the valves, clean them up, I lubricated the disks with silicone grease, and put them back in. They worked fine after that. Or buy new valves and remove the old ones and install the new. There are temp fixes where you can buy a valve that hooks onto the outlet of the piping. Then you use that to shut the line off. You can see what the valve looks like. I'd call this a knife valve. Edited December 6, 2019 by agesilaus Quote Link to comment Share on other sites More sharing options...
Kirk W Posted December 6, 2019 Report Share Posted December 6, 2019 I agree with the post above. If they are leaking you probably need to replace them and this isn't difficult or expensive, if you have reasonably good access to them. There are two of them and they are not the same size. The valve for the black tank is 3" in diameter while the gray tank valve is 1.5" in diameter. They look pretty much the same except for the size. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Pappy Yokum Posted December 11, 2019 Report Share Posted December 11, 2019 (edited) On 12/4/2019 at 5:07 AM, Kirk W said: The dump valves for your waste tanks are removable and you can replace them fairly easily as long as you have reasonably good access to them. Kirk supplied good links in his second post. However - - "..........you can replace them fairly easily, as long as you have reasonably good access to them". The "good access" may be *VERY* difficult access! In the good old days, the valves *were* easily accessible - usually *externally* on the 3" drain pipe....reach down, pull the valve = EASY access! Depending on what type of RV you have, the valve may be *WAY* underneath the RV, and may have a cable (or electric) actuated valve - rather than the "pull handle". Replacement requires you (or the installer) to be underneath the RV. You didn't say what type you have - Often the problem is the cable connection FROM the pull handle TO the valve. - or the valve is not actuating (electric) for whatever reason. It is definitely *NOT* easy access!! - Nor is it an easy job to replace it! - Been there, done that! As others have suggested - try a thorough flush - or multiple flushes. Some folks suggest adding some veg oil in the water (do not use drain cleaners). If it's a cable type - don't try to force the cable! Hard "pulls" (or "pushes") on the cable -to try to make the valve operate- may have initiated "play" in the connection - or a kink in the cable. Mfgrs can be sloppy about the mounting - which allows kinks to be "forced" after years of use. If you don't have any success with that......replacing the valve is necessary. Yes, you could replace *just* the seals - but that requires removing the valve anyway. Google "Valterra Waste Valve" - on the mfgr's site go to "Waste Valves and Accessories". A quick and easy solution - is a Valterra "twist on" valve - which you add to the end of the 3" drain pipe. You then attach a cap or the drain hose (when it's time to drain) as you do now. (Every RV'er should have one - cheap insurance!). Lastly - there are YouTube videos which should help understanding the valves & the process of replacing them. (Google should give you "hits" to those). Ask one of your neighbors! - If they have waste and gray water tanks - they gotta know, LOL. ~ Edited December 11, 2019 by Pappy Yokum Quote Link to comment Share on other sites More sharing options...
Barbaraok Posted December 11, 2019 Report Share Posted December 11, 2019 We have replaced them - while it was probably easy to install before the rest of the motorhome was built around it, it is down right HARD to replace. Took us from 10:00 am to 4:00 pm to finally get it all done and cleaned up! And when people see you working on your wet bay, especially the tanks, they will cross the street and way to make sure they are away and don't have to offer to help! 😎 Quote Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
Pappy Yokum Posted December 11, 2019 Report Share Posted December 11, 2019 (edited) Bingo !! - ( I) Should have linked this one..... GREAT (Youtube) VIDEO - - "All you need to know" - "RV Waste Valve Repair & Maintenance by RV Education" - Valterra (10minutes!) http://www.youtube.com/watch?v=toD1epBKjnc ...don't forget, click where indicated to- "skip ads" ! ~ Edited December 11, 2019 by Pappy Yokum Quote Link to comment Share on other sites More sharing options...
Kirk W Posted December 11, 2019 Report Share Posted December 11, 2019 2 hours ago, Barbaraok said: while it was probably easy to install before the rest of the motorhome was built around it, it is down right HARD to replace. I guess there is some advantage to our current, seasonal RV as the dump valves on it are very easily accessible. They are about 18" in from the edge of the RV and in the open. When I changed one of them on our previous motorhome, those were inside of a wetbay but once some cosmetic panel was removed they too were not that difficult. Removing the panel was the most difficult part. But I also once assisted a friend in the same job on his fiver that used cable pulls for the dump valves that was a really nasty, all day job with two of us working. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted December 12, 2019 Report Share Posted December 12, 2019 (edited) 22 hours ago, Kirk W said: I guess there is some advantage to our current, seasonal RV as the dump valves on it are very easily accessible. They are about 18" in from the edge of the RV and in the open. When I changed one of them on our previous motorhome, those were inside of a wetbay but once some cosmetic panel was removed they too were not that difficult. Removing the panel was the most difficult part. But I also once assisted a friend in the same job on his fiver that used cable pulls for the dump valves that was a really nasty, all day job with two of us working. MIne is hard to access also. Thankfully the extended service contract paid the bill to replace all three leaking valves, except for the $50 deductible. Edited December 12, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Kirk W Posted December 12, 2019 Report Share Posted December 12, 2019 This conversation makes me think that it could be that we should consider the ability to access things which could need repair when we shop for an RV. As one who made a career in service and repair work, it has always been one of the things that I look for, but I'm not so sure that I have ever mentioned it as a consideration for a person new to buying an RV. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
agesilaus Posted December 13, 2019 Report Share Posted December 13, 2019 I guess you need to consider freeze proofing. Getting all wet lines up inside the belly Coreplast. At least on the 5ver I worked on they were under the Coreplast but within a foot or so of the side. Burying them deep inside the belly is a real problem. But how would you know when buying a unit? I doubt a dealer will willingly pull the belly off for you to look. And I have never even heard of a piping diagram of one of these units. Quote Link to comment Share on other sites More sharing options...
Pappy Yokum Posted December 13, 2019 Report Share Posted December 13, 2019 On 12/11/2019 at 1:56 PM, Kirk W said: But I also once assisted a friend in the same job on his fiver that used cable pulls for the dump valves that was a really nasty, all day job with two of us working. I did that job - under a fiver - and it's way worse than being under your car or truck. Raising the 5er doesn't help a whole lot. It was on concrete with lots of space. (Didn't matter). Sooooo - I added another (secondary & accessible) pull valve in the 3" line, closer to the termination point and easily replaced should the need arise. *If* the "main" valve leaks - it can just leak - or stay open! A "twist on" valve is in the storage bay - as back-up to the back-up. Moral of the story (stories): Take excellent care of your plumbing. BTW - never had any parts/repair insurance on any of the RVs I've had- since 1975! Never needed any. My 5th had 2 years (factory), but the valve problem was long past 2yrs. Guess I'm money ahead on that one......but (one time?) "PITA Repair" ins would have been nice! ~ Quote Link to comment Share on other sites More sharing options...
Ronbo Posted December 13, 2019 Report Share Posted December 13, 2019 I abandoned the valves buried in the belly installed by the manufacturer. They are left open. I added new valves to the pipes on the exterior of the rv. Easy to repair and use. For your leaky valves, try adding 1 cup of cooking oil to each tank after you empty them. It will lubricator the blades and seals. Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
rickeieio Posted December 13, 2019 Report Share Posted December 13, 2019 Abandoning the interior valves in favor of adding exterior valves may bite you later. Sometimes you can't avoid being in freezing weather. A few years ago, we were headed south and ran into freezing rain on I-10 between NOLA and Houston. We were lucky to duck into a campground just before they closed the interstate, and had two mornings with temps in the teens. There are reasons those valves are buried...... Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Pappy Yokum Posted December 13, 2019 Report Share Posted December 13, 2019 11 hours ago, Ronbo said: I abandoned the valves buried in the belly installed by the manufacturer. They are left open. I added new valves to the pipes on the exterior of the rv. Easy to repair and use. For your leaky valves, try adding 1 cup of cooking oil to each tank after you empty them. It will lubricator the blades and seals. Repeat at least 5 times: Xlnt plan!! *If* you're worried about freezing temps - wrap with some elect heat tape, or some other plan B. ~ Quote Link to comment Share on other sites More sharing options...
rls7201 Posted December 22, 2019 Report Share Posted December 22, 2019 Before you start working on those valves, raise the right side and dump. Then before you remove the valves, raise the left side and any drips that are left in the tank will be away from the valve. No Mess......... Richard Quote Richard Shields Gladstone, MO 95 Bounder 32H F53 460/528 stroker engine Link to comment Share on other sites More sharing options...
KodiakJack Posted December 22, 2019 Report Share Posted December 22, 2019 (edited) 9 hours ago, rls7201 said: Before you start working on those valves, raise the right side and dump. Then before you remove the valves, raise the left side and any drips that are left in the tank will be away from the valve. No Mess......... Richard Darn good idea Richard. The only spot I could access our black tank valve when I replaced it and was directly under it. So I put a towel over my face to catch any surprises I might have missed and peeked around it. Your method would have helped. Later, J Edited December 22, 2019 by KodiakJack typo Quote 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
Ray,IN Posted December 23, 2019 Report Share Posted December 23, 2019 On 12/12/2019 at 8:13 PM, Pappy Yokum said: I did that job - under a fiver - and it's way worse than being under your car or truck. Raising the 5er doesn't help a whole lot. It was on concrete with lots of space. (Didn't matter). Sooooo - I added another (secondary & accessible) pull valve in the 3" line, closer to the termination point and easily replaced should the need arise. *If* the "main" valve leaks - it can just leak - or stay open! A "twist on" valve is in the storage bay - as back-up to the back-up. Moral of the story (stories): Take excellent care of your plumbing. BTW - never had any parts/repair insurance on any of the RVs I've had- since 1975! Never needed any. My 5th had 2 years (factory), but the valve problem was long past 2yrs. Guess I'm money ahead on that one......but (one time?) "PITA Repair" ins would have been nice! ~ You are right, my waste valves are behind steel panels, front, side, and bottom. Water tank drain valve is 32" from nearest access, and only one arm at a time in the opening. If I remember correctly the total for replacing those 3 valves was over $1,400 including the special Winnebago cable valves.. I was sure glad we had the ESC. BTW, I also carry a twist-on valve, JIC. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Ronbo Posted December 23, 2019 Report Share Posted December 23, 2019 On 12/13/2019 at 5:36 AM, rickeieio said: Abandoning the interior valves in favor of adding exterior valves may bite you later. Sometimes you can't avoid being in freezing weather. A few years ago, we were headed south and ran into freezing rain on I-10 between NOLA and Houston. We were lucky to duck into a campground just before they closed the interstate, and had two mornings with temps in the teens. There are reasons those valves are buried...... We have been down to the teens without much issue. When the pipes have frozen I put a space heater .on them and it thaws it out. I also make sure my tanks are empty going into a low temp event so I have a few days to go. So fat it has always risen to about he 40’s after a freeze. Quote Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
