alan0043 Posted December 28, 2019 Report Share Posted December 28, 2019 This is just an idea. Stop my a glass shop and see what they would say. I think there is a couple different sealants out there for windshields. One more think. Nice work. Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Moresmoke Posted December 28, 2019 Report Share Posted December 28, 2019 4 hours ago, jenandjon said: Got a hole cut and test fit. Got it mocked up on the inside. Looks like everything is going to fit like its suppose to. Now I have to figure out what to use for a sealer and get it together. It first I thought I might use the stuff they use on windshields. But if that window ever broke you would never get it out. The black gooey stuff they use to seal roped in windshields would work. It’s quite similar to the gray butyl caulk the RV builders use, just black. If you are talking about the urethane windshield adhesive, I wouldn’t use it if you have all the trim rings that clamp the window in. You are right the only way to get that stuff to let go is to cut the window out. That’s how mine are installed, just glued in from the outside. The urethane adhesive is fairly expensive, and requires proper prep to adhere correctly. Just a thought, the RV butyl tape is very similar to the tape they use on grain bins... Quote Link to comment Share on other sites More sharing options...
jenandjon Posted December 29, 2019 Author Report Share Posted December 29, 2019 Are you talking about bedding and glazing compound? Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
Scrap Posted December 29, 2019 Report Share Posted December 29, 2019 Ya I use the 3M Window Weld butyl tape rolls on the flange to put em in. Right or wrong I dunno, but I don't use the spacers in the box and I kinda pre-flatten the bead with an ice cube. Join the bead at the bottom and run the two side by side for a few inches - not overlapped or the window sets fat at the bottom. The caulk gun style butyl might work better for a more custom more squishy bead but I got banned from that. That goo gets everywhere forever! That's on newly painted truck in a warm shop though. Oxidized paint done outside probably needs a hair dryer and I imagine should use the black window weld primer that the urethane type uses. Don't drip or primer out too wide! Quote Link to comment Share on other sites More sharing options...
noteven Posted December 30, 2019 Report Share Posted December 30, 2019 Ya don’t stick it with product designed for structural windshields. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
jenandjon Posted December 31, 2019 Author Report Share Posted December 31, 2019 I got some 3M butyl tape from a local body shop. Window going in today pics to follow. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
jenandjon Posted January 1, 2020 Author Report Share Posted January 1, 2020 All done. Used 3M butyl tape as a sealer. Seems to have worked well. I found out that when you put on the final trim piece on the inside just snug the screws. If you tighten them too tight they will pull through the plastic. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
rickeieio Posted January 1, 2020 Report Share Posted January 1, 2020 👍👍 Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Chad Heiser Posted January 1, 2020 Report Share Posted January 1, 2020 Nice job. Quote 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Scrap Posted January 1, 2020 Report Share Posted January 1, 2020 Yea nice! Quote Link to comment Share on other sites More sharing options...
Moresmoke Posted January 1, 2020 Report Share Posted January 1, 2020 Sweet, we knew you could do it. Quote Link to comment Share on other sites More sharing options...
jenandjon Posted January 1, 2020 Author Report Share Posted January 1, 2020 Thanks guys. I was pretty nervous cutting holes in my cab but it wasn't has hard as I made it out to be. My boys love it they are excited. No more missing the scenery. I am amazed how much light comes in that small of a window and I haven't even had it outside in the sunlight yet. Now I just have to do the other side. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
alan0043 Posted January 1, 2020 Report Share Posted January 1, 2020 Nice job. I like it. I would have been nervous myself cutting a hole in the side of my truck. Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted January 1, 2020 Report Share Posted January 1, 2020 7 hours ago, alan0043 said: Nice job. I like it. I would have been nervous myself cutting a hole in the side of my truck. Al Al, trust me I’m not nervous about cutting a hole in the side of your truck or Jon’s. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted January 1, 2020 Report Share Posted January 1, 2020 That 3M tape is where it's at. I zoned on that flavour of putty tape, but you won't regret using it. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Wrknrvr Posted January 2, 2020 Report Share Posted January 2, 2020 The windows will also help with seeing out for driving at odd angles. Such as in parking lots or maneuvering in camp grounds. I waited 10 years to do ours. Wife did not want the windows, but I showed up one day with two from a Motorhome. Now it would be a must have for another truck. So you will like them when driving. Nice job, Vern Quote Link to comment Share on other sites More sharing options...
alan0043 Posted January 2, 2020 Report Share Posted January 2, 2020 16 hours ago, Hewhoknowslittle said: Al, trust me I’m not nervous about cutting a hole in the side of your truck or Jon’s. Hey Roger, now that doesn't surprise me ! lol. Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted January 3, 2020 Report Share Posted January 3, 2020 Nice work! Quote 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
tyates007 Posted January 4, 2020 Report Share Posted January 4, 2020 Those look great. Nice job. Our first trick did not have windows. Our KW does and the little girls like it much more. Of course now that they are growing and into their mobile devices the windows don’t seem to get used as much when we travel. Quote Link to comment Share on other sites More sharing options...
HERO Maker Posted January 6, 2020 Report Share Posted January 6, 2020 Nice job! Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
