Dlvgolf Posted November 27, 2019 Report Share Posted November 27, 2019 (edited) When I post, I always feel like I’m at a meeting, “ Hi, my name is Dave and I’m a newbie. I’ve been RV’ing for 1 week...”. Any way, today’s adventure is installing a TPMS system on my RV and tow vehicle. 10 tires in all. I bought the TST pass through system. I’m familiar with 3rd party TPMS, as I have them on my motorcycle. Programming of the 10 sensors went fine. Installation was where I found the challenge. I’ve never had a vehicle with dual back tires, so I had no idea how the stems worked. I expected one to come out to the outside and the other the inside. I was so wrong. On my vehicle, The inside tire stem has a flexible extension on it and it comes through the outside tire rim. Very convenient. However the outside tire stem can be seen under the rim pointing toward the inside tire. I’ve attached a picture. My questions are, how do you even get a tire gauge on that tire stem to get the air pressure, let alone attach a TPMS monitor to it? Is this the standard configuration for dual tires or are mine out of whack? Edited November 27, 2019 by Dlvgolf Fixed typos Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted November 27, 2019 Report Share Posted November 27, 2019 (edited) Welcome to Escapees.com discussion forums! That stem positioning is unusual, but not unheard of; There are stem extensions sold to enable you to adjust air pressure, they even have 180° extensions but I doubt you'll require them. That is not the only company selling these, shop around for the best pricing. These are not the ideal situation, as they add another possible air leak to the arrangement, and allow the pressure monitor to move/vibrate more, which weakens the valve stem. When you have the opportunity, have permanent valve stems with the correct bend in them+ stabilizer grommets, to point outward, they are expensive and well worth the money IMO. Please do not hesitate to ask any question, that's how people learn, everyone here was a beginner at one point. Edited November 27, 2019 by Ray,IN lapse of memory Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
LindaH Posted November 27, 2019 Report Share Posted November 27, 2019 45 minutes ago, Ray,IN said: Welcome to irv2.com! Wrong forum! Quote LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
rockylarson Posted November 27, 2019 Report Share Posted November 27, 2019 Quote My questions are, how do you even get a tire gauge on that tire stem to get the air pressure,Dually air chucks Quote Jan and Rocky Larson, Volunteers, USFWS , 9,300 hours each. 29 refuges since 2006. 2 new each year. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty, Blue Ox Aladdin, 300 watts solar, 5 Optima group 31 AGM's, 2000w PSW inverter Philippians 4:11-13 KJV Link to comment Share on other sites More sharing options...
Ray,IN Posted November 27, 2019 Report Share Posted November 27, 2019 (edited) 8 minutes ago, LindaH said: Wrong forum! Thanks for the catch! My fault for attempting to do 3 things at once. Edited November 27, 2019 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
ToddF Posted November 27, 2019 Report Share Posted November 27, 2019 I recommend looking for a dealer (auto/rv service tech) familiar with RVs who can install permanent valve stems that come out of the wheel cover for easy access. It takes some doing...many Ford dealers have no idea how to do it! We found Kremer Services in Inver Grove Heights MN who was familiar with the process and ordered the parts. Now checking tire pressure is a breeze. Not happy with our $500+ Tiretracker system. Sensors fall off the radar. Sensors give inaccurate readings. The display terminal inside the RV doesn't sound an alarm if a tire is suddenly deflated. (tested it). They have a lifetime warranty so we have to pack it up and send it back to them. Junk as far as I am concerned. AVOID THIS COMPANY: https://www.tiretraker.com/ Quote Link to comment Share on other sites More sharing options...
TexasPSDX Posted November 28, 2019 Report Share Posted November 28, 2019 The first thing I would do is install valve stem stabilizers. Mine did not have them and I wore a hole through the extension. These are the ones I installed. https://www.raneystruckparts.com/valve-stem-stabilizer/ Quote Ron 2020 Ram Longhorn 6.7 4D SB 1989 Avion 34V Link to comment Share on other sites More sharing options...
Dlvgolf Posted November 29, 2019 Author Report Share Posted November 29, 2019 8 hours ago, TexasPSDX said: The first thing I would do is install valve stem stabilizers. Mine did not have them and I wore a hole through the extension. These are the ones I installed. https://www.raneystruckparts.com/valve-stem-stabilizer/ Thank you! Quote Link to comment Share on other sites More sharing options...
Dlvgolf Posted November 29, 2019 Author Report Share Posted November 29, 2019 On 11/27/2019 at 1:07 PM, Ray,IN said: Welcome to Escapees.com discussion forums! That stem positioning is unusual, but not unheard of; There are stem extensions sold to enable you to adjust air pressure, they even have 180° extensions but I doubt you'll require them. That is not the only company selling these, shop around for the best pricing. These are not the ideal situation, as they add another possible air leak to the arrangement, and allow the pressure monitor to move/vibrate more, which weakens the valve stem. When you have the opportunity, have permanent valve stems with the correct bend in them+ stabilizer grommets, to point outward, they are expensive and well worth the money IMO. Please do not hesitate to ask any question, that's how people learn, everyone here was a beginner at one point. Thank you! Quote Link to comment Share on other sites More sharing options...
