scouserl41
LED replacement bulbs
i will stick with my normal bulbs till they burn out. (decades from now). as the anti green leds are way over priced. --$25,usd ver $0.50 cents. vanity blub in my rv.--
(i say anti green as nothing in a led is recyclable, but everything in a incandescent bulb is).
as i have never had a electric supply problem running reg light bulbs. so at least for me there is no reason to drop $100.usd or more just for "change".
Share this post
Link to post
5 hours ago, packnrat said:
the anti green leds are way over priced. --$25,usd ver $0.50 cents. vanity bulb in my rv.--
With all due respect, we've replaced every single light in our MH with LEDs and I've yet to pay more than a couple of dollars each, at most.  I recently replaced the halogen in our over-the-range GE microwave/convection oven.  A year or so GE advised me that no suitable LED substitute existed--not so this year.  The bulb I bought cost $3 and provides nearly as much light as the hot, 50W halogen it replaced and works without flicker even on the "low intensity" setting.
Share this post
Link to post
Yes, in many cases cheaper than regular bulbs, and normally draws less than 1/8 the amperage of an incandescent for the same lumens. I have 60 g4 puck lights in my coach, and I replaced them all for about $22. And as you say a lot less heat and a lot less power used. If all on, incandescent 600 watts, with led, 90 watts. Works out to about 36 cents per bulb.
https://www.ebay.com/itm/20X-4000K-Warm-White-G4-LED-5050-DC-12V-Landscaping-Bulb-lights-Home-Lamps/301311785979?hash=item462794fbfb&_trkparms=ispr%3D1&enc=AQAEAA
Edited by jcussen
Share this post
Link to post
i am not sold on led's. sure they use a little less juice, and put out light in the wrong color spectrum, so just looks like more light some times,  then the new headlights on cars and trucks, hurt my eyes.
and the ones i looked at to replace my very usable ones are very costly.  as to longevity. i say hog wash as i see so many of them out at traffic lights, and they have to be replaced a lot on the rigs at work. (outside and inside lights).
in my 5er, the bulbs are a good 18 years old (maybe longer due to warehousing time). rv new in 2001.  so i still have lots of time on them.
only one "burned" but it was the connector that failed, and the vanity it was the glue not the bulb that failed.
but i do have this box of running lights (red-amber) that are leds, as the cheap ones from the factory, the lens, bases are cracking apart, falling off the coach  and letting water in.
reg dot commercial lights are made better. yes still plastic, but twice as thick. replacing these due to many fails of the plastic lens, O and i can get replacement lens and parts almost everywhere. but i am saving the bulbs for use inside, if any, ever do burn out.
i am 60, and at the rate they are working and lasting me, i will be long gone and forgotten before i run out of them.
but then if/when i buy a new rv, it will be all leds from the start...maybe.
Edited by packnrat
Share this post
Link to post
Although I doubt this is going to change your opinion, but, as jcussen already noted, LEDs use roughly 1/8 the energy of incandescent bulbs so it's not just "a little less juice."  Furthermore the "color temperature" of the light produced by LEDs is quite controllable.  There are plenty of "warm white" bulbs available these days that you are hard-pressed to tell aren't incandescents with respect to the light spectrum they provide. As for the LEDs used for car headlights, yes, automakers do use LEDs that produce blue-white light because those are the most energy efficient and least expensive to produce.
Yes, you do see traffic lights with unlit LEDs, but that could be caused by manufacturing failures as well as burnout.  The attached article from the Department of Energy estimates that high power white LEDs will last 30,000-50,000 hours which is far longer than the lifetime of any alternative light source..  However, it should be noted that 50,000 hours represents "only" 5.7 years of continuous use  so you could, in fact, be seeing traffic lights experiencing LED failure because they have reach their design lifetimes.  If you'd like to read the article you can find it here:  Lifetime of white LEDs
Share this post
Link to post
X2  and X3 especially in changing terrain
Clay
Share this post
Link to post
if they are coming out with these crazy hot lights, then i will repay in kind with my off road flood lights,  and mine are far brighter.
not good for the factory to build headlights that blind oncoming traffic.
Share this post
Link to post
I LOVE LED's in my RV, have replaced all the old incandescent and wouldn't go back !!!! If you shop on Amazon or E Bay or any of the other thousands of sources you can find them in the Lumen and Kelvin temperature rating and the price and quality of your choice SO INEXPENSIVE. As an electrical engineer I like the fact they use sooooooooooo much less energy, more light per watt, and produce so much less heat.
HOWEVER I  believe each should use what they please and what works best for them  be it incandescent or halogen or sodium or LED ….
John T
Share this post
Link to post
On 11/8/2019 at 12:14 AM, scouserl41 said:
My previous post about replacing bulbs with LED's was popular and I just updated it to include halogens.
Hope it helps
You also make video like this, a video attracts more eye balls and it's easier to consume.
Share this post
Link to post
Moot point.  I've never heard of anyone recycling light bulbs.
I've replaced a few lights w/ led's.  The fixtures in the shop made a huge difference. I put all led's on the truck bed when I built it, and have converted a few tractor lights to led too.  The price is coming down dramatically.
Share this post
Link to post
IMO factory LED headlamps do not blind oncoming traffic, it's the after-market replacement LED bulbs in incandescent headlamp assemblies that blind me, and everyone else that's meeting the  vehicle. The old incandescent reflectors are not designed for the LED bulbs.
Our Lincoln MKX had OEM LED headlamps, when I pulled up to our white garage door there was a definitive line where the illumination stopped, no beam scatter whatsoever. There was no reflection off the white door to catch my eyes either.
Share this post
Link to post
I took a box of the old spiral-type bulbs to the recycle center, they told me to put them in my trash basket, as there was no one to send them too. BTW those have a small amount of mercury in them, just like tubular florescent bulbs.
Share this post
Link to post
the earth recycles them.
it is not a forced human thing, just “if” the item was just tossed onto the ground.
plastic will be there for ever and ten days.
glass and tin will be reduced back the native elements.
Share this post
Link to post
Glass will NEVER decompose. while plastics do, but some do it very slowly.  Tin is an element, thus it will degrade, but never decompose.
Regardless, both conventional and led's take up space in landfills, but led's will take up far less.
Share this post
Link to post
i never said "decompose". needs to be organic to decompose.
but glass is only refined and melted sand. plastic does not decompose. or return to its native elements. sure weather can erode it to plastic dust. but that is not a nat element.
and everything non food (organic) stuffs, just buried under ground will tend to stay that way for a very long time, as in many human life times.
glass is very durable that way, but in the open, or in a river setting it will erode over time, and return to its sand beginnings.
to me what happens in the end to the product mtr is the answer. not how long it will last.
no i am not one of tho's environmental nut cases. just for me less garbage is better.
i can not remember the last time i placed a normal light bulb in the trash. but i have dumped a number of leds in the trash in the past couple of years. (home use stuff).
i always smash the glass bulbs.
mercury vapor, in the house i avoid like the plague. yes i have some tubes in the garage. have had them for many years. never a problem as long as the glass is not broken. but nothing worth it to replace them with. but the price has gone up to way over board. so in the future? if they ever burn out.
Edited by packnrat
Share this post
Link to post
With all due respect, it's my understanding that even when glass breaks into tiny shards it retains its "glass-like" vitreous character. Yes, it starts life as sand but it doesn't become sand ever again.
Share this post
Link to post
Packrat, would you please give me the link for your statement:
Quote
Because as a chemist/chemical engineer I want to see the research on this  phenomena.  Yes, there are sands than contain volcanic glass, but under the microscope those are glass bits, not sand grains.  Now, if you use pressure and heat, say in a volcano, then you would form magma, which might flow out as molten rock which when cooled, would go through erosion and finally become sand (and sand is different all over the world).   And the type of sand would depend upon the types of other minerals beside SiO2 in the magma, which is dependent upon the place on the mantel that the hotspot occurs.
Share this post
Link to post
9 hours ago, packnrat said:
and if leds are so great, why did the government ban the making and importation of normal incandescent bulbs?
Because people in the USA would continue buy them because they are cheaper even if they harm the environment in the long run.   That's what being scientifically illiteracy does to a country.    Short-term, what's in it for me versus long-term, what is good for everyone on the planet in the coming centuries.
Share this post
Link to post
but glass is only refined and melted sand. plastic does not decompose. or return to its native elements. sure weather can erode it to plastic dust. but that is not a nat element.  .........
Actually there are microbes that 'eat' plastics and some engineered enzymes that break down plastic into shorter chains that bacteria/fungi can use.   This is a very hot area of research - we have a friend involved in some of the engineered enzymes, very intriguing.
Edited by Barbaraok
Share this post
Link to post
With all due respect, incandescent light bulbs haven't been banned.  What has happened is that the government has imposed an efficiency standard similar to what was done for home air conditioners, automobiles and lots of other things.  I've provided an article which explains the issue in more detail:  Incandescent lights haven't been banned
There's a lot of misinformation spread on the internet by people who want to make a political statement out of something like this.  It usually doesn't take all that much effort to get to the truth.
Share this post
Link to post
Rv Insurance Benefits.com Logo
AGS Now Hiring
RV Pet Safety
