GlennWest Posted November 2, 2019 Report Share Posted November 2, 2019 (edited) On my Litlium/ inverter projuct I have been comtemplating using one of the Mangum MPSH250-30D. They are very nice and makes it all simple. They are right at $1200.00. Seems I can go without and save right much money. Seems a few breakers and buss bars would do the job. Your thoughts. Midnites E panels are less but I would have to add a breaker for multiple inverters. Edited November 3, 2019 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted November 4, 2019 Author Report Share Posted November 4, 2019 unless someone tells me differently, i have decided on the Midnite MNE175STM-240-E panel. I can get it for $500.00. I has everything the Magum has.It comes with 1 inverter disconnect and I will have to add for each additional one. Same with Magnum. Only real difference is side mounted breakers vs front mounted on Magnum. This allows for 1 inveter to mount on door. Solar controler on side.I intend to use the Midnite Classic 250 controler. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
DesertMiner Posted November 4, 2019 Report Share Posted November 4, 2019 Why do you need this panel? It seems to me most of the functions of this over priced attachment point can be replicated in a less expensive manner and with the option of greater flexibility. Do you have enough space to accommodate it? Quote Link to comment Share on other sites More sharing options...
GlennWest Posted November 4, 2019 Author Report Share Posted November 4, 2019 Seems to me it may actually save space. I will have to buy boxes for the breakers, run all the wiring for them. Add the buss bars. The shunts and all the wiring and attachment points. Also my solar controller will attach to side of panel box. I may mount one inverter on box also. Just be one to mount separate. Saves a lot of time also. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted November 4, 2019 Author Report Share Posted November 4, 2019 (edited) Deleted Edited November 4, 2019 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted November 5, 2019 Author Report Share Posted November 5, 2019 On 11/3/2019 at 9:11 PM, DesertMiner said: Why do you need this panel? It seems to me most of the functions of this over priced attachment point can be replicated in a less expensive manner and with the option of greater flexibility. Do you have enough space to accommodate it? You might be right about this. All I really need is 2 175 disconnects/breakers. Few busss bars. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Daveh Posted November 10, 2019 Report Share Posted November 10, 2019 Yeah. They are pretty and convenient but are they THAT pretty and convenient. Quote Dave and Lana Hasper Link to comment Share on other sites More sharing options...
GlennWest Posted November 11, 2019 Author Report Share Posted November 11, 2019 The owners manual on the PAE converters really push the panels. Go to stacking inverters and that is all they really show. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
