Landing gear goes up but not down
Imoski
The story so far...
Landing gear came worked fine this morning (extended to hitch to truck; retracted for storage)
At new campsite tonight they won't extend but will retract.
I got them down manually with the handle to stabilize the 5th wheel for tonight.
Any ideas why they go up but not down?
Thanks!
12 minutes ago, chirakawa said:
Bad contact on the switch.
I'll 2X that.
26 minutes ago, Imoski said:
That's what I'm hoping.
I would also check the switch first as that sounds like a strong possibility. Most likely you have a switch that is open in the center position and closed either of the other two positions(raise & lower). It may have one bad set of contacts. You can easily check it with an ohm meter, or as a quick test just use a jumper wire to connect between the lower contacts and the center. It will be very helpful if you have a multi-meter and are familiar with it's use.
