Cotreker Posted October 21, 2019 Report Share Posted October 21, 2019 I am researching diesel fired cab heaters to use in my basement of the RV to stop water lines from freezing. The RV is used in -15 degrees temps so this could be a very useful heater to help keep the rest of the camper warm. My question has anyone used these if so which brand? They appear to run on 1 gallon for about 24 hours plus some 12v draw. Webasto Happybug (China) Superfastracing Espar Airtronic D2 Planar Others???? Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 21, 2019 Report Share Posted October 21, 2019 I'd be buying based on dealer network. Webasto and Espar both have good coverage for parts or service. If you compulsively hoard parts, this might not affect your choice, but waiting for Amazon with a freezing forecast doesn't sound like fun. I've run both of the above, and only had issues from fuel quality. Think nozzles and filters. Bad fuel can play havoc with the spare parts inventory. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Wrknrvr Posted October 21, 2019 Report Share Posted October 21, 2019 Another fairly simple thing to do if your Rv has the ability is to run extra ducts into the lower area. Many Rv gas furnaces do not use all the duct openings on the furnace. Also some rv's have more than on furnace. Ours has two furnaces, but I could only run one extra duct into the basement under the rear of the fifthwheel. The other thing is to partially block some heat ducts that produce more heat but is not needed as much as others. I have also duct heat into the storage area under the bedroom and then have a few 4" holes in the floor hidden somewhere. The first one I had two 4" openings under the bed. Then had a few 4" openings towards the front of the Rv on the side of the bed. The idea to get heat under the floor will make the whole Rv much more comfortable. In cold weather. Just a thought, Vern Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted October 21, 2019 Report Share Posted October 21, 2019 Webasto for $648 + free shipping: https://www.ebay.com/itm/Webasto-Air-Top-2000-STC-12v-Diesel-Night-Air-Heater-with-full-mounting-kit/122838226201?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3Db2c6245068234370b974517f832860d5%26pid%3D100623%26rk%3D3%26rkt%3D6%26mehot%3Dpp%26sd%3D223178923022%26itm%3D122838226201%26pmt%3D1%26noa%3D1%26pg%3D2047675&_trksid=p2047675.c100623.m-1 Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
ALLOY Posted October 26, 2019 Report Share Posted October 26, 2019 Wallace is another diesel option. https://www.scanmarineusa.com/products/heaters/ and Propex if you have propane https://www.propexheatsource.com/ Quote 2011 Cameo 34SB3 Link to comment Share on other sites More sharing options...
ARGO Posted October 27, 2019 Report Share Posted October 27, 2019 Well, in "the old days" when I was truckin' & it was a cold night, I had an electric little heater. Power? I stole the special plug from a phone booth & spliced it in, pulled up to any phone booth for heat. Quote You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
noteven Posted October 27, 2019 Report Share Posted October 27, 2019 A customer called me one January morning. He was parked to sleep in central AB at -30c KW T660 72” Aerocab Aerodyne. His Webasto Airtop heater was holding the cab at 18c for sleeping at 1/2 throttle on the dial. His Webasto TL17 coolant heater had the ISX starting happily. We point the coolant heater exhaust at the oil pan in the winter time. These heaters sip fuel and DC electricity vs cold idling a $40,000 engine. Diesel fuel has very high btu density maybe 2x propane so you need less tankage to store fuel. If you have large propane capacity the propane heaters are worth a look too. wrknrvr showed me his basement heat system it’s pretty slick Heated air applied to a basement wants to rise like a bloon or leave to the outdoors so do what Vern did and seal the leaks... Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Cotreker Posted January 31, 2020 Author Report Share Posted January 31, 2020 Update: Just came across this place that sells lots of Webasto heaters and other brands. Apucenter.com 417-736-3000 Webasto out the door for $700 pretty sure they are the good USA branded models yes made in Germany, 1 yr warranty but 2 yr warranty if they do the install. This winter we could have used one of these while snowmobiling, temps got down to -15 at night. Snow has been great the bath vanity did freeze up for a few hours. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Ray,IN Posted January 31, 2020 Report Share Posted January 31, 2020 (edited) This is compilation of ebay diesel cab heaters for sale. Sure beats $700 for one. Edited January 31, 2020 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
