runaway parents Posted October 19, 2019 Report Share Posted October 19, 2019 Been haveing trouble with a diesel powered generator -welder . Started to run like it was running out of fuel (which it had a full tank)went to change the fuel filter and looked at the fuel in the filter bowel and although it was dyed red it seemed to be cloudy. Is this normal for off road diesel? Quote Link to comment Share on other sites More sharing options...
spindrift Posted October 19, 2019 Report Share Posted October 19, 2019 (edited) No. Cloudy as in "murky"? Air entrainment will make diesel appear cloudy. Edited October 19, 2019 by spindrift Quote 2012 F350 KR CC DRW w/ some stuff 2019 Arctic Fox 32-5MCindy and Tom, Kasey and Maggie (our Newfie and Berner) Oh...I forgot the five kids. Link to comment Share on other sites More sharing options...
runaway parents Posted October 19, 2019 Author Report Share Posted October 19, 2019 3 hours ago, spindrift said: No. Cloudy as in "murky"? Air entrainment will make diesel appear cloudy. I guess you can call it murky. How is air getting into diesel between the tank and fuel filter? Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 20, 2019 Report Share Posted October 20, 2019 1 hour ago, runaway parents said: I guess you can call it murky. How is air getting into diesel between the tank and fuel filter? Depends on the fuel system. Does the filter screw into the bottom of the tank? Any fuel line can let a little air in, while barely showing a sweat of diesel fuel on the outside. Especially if the filter was getting plugged, even more so if there's a fuel pump involved. The rubber line can also start to collapse internally, and cause fuel cavitation, again with a fuel pump. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
runaway parents Posted October 20, 2019 Author Report Share Posted October 20, 2019 34 minutes ago, Darryl&Rita said: Depends on the fuel system. Does the filter screw into the bottom of the tank? Any fuel line can let a little air in, while barely showing a sweat of diesel fuel on the outside. Especially if the filter was getting plugged, even more so if there's a fuel pump involved. The rubber line can also start to collapse internally, and cause fuel cavitation, again with a fuel pump. I think I have an idea what's wrong with this welder. this welder is mounted on a trailer we move it buy hanging it buy a chain under a all terrain fork lift. while it is still running so we don't put the temp lights out and shutting down saw stations. while hanging it is not level. which I think the fuel supply line is higher than the fuel level which maybe sucking air into fuel system. let me describe this welder in detail .this welder had a issue with the stock fuel tank which was on top of the engine they could not replace with a stock tank so they mounted one underneath the engine in the frame the fuel filter and pump is still mounted on the engine in the stock position. probably need to be shutting this thing down before we move it. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted October 20, 2019 Report Share Posted October 20, 2019 Find a tank that will fit correctly. Gravity is much more reliable than pumps. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Lance A Lott Posted October 20, 2019 Report Share Posted October 20, 2019 Alge, or what ever it is called, will make the fuel cloudy or so I have read. Does the filter have coffee grounds in it? This will make it act like it's running out of fuel, as my parents found out. Quote Link to comment Share on other sites More sharing options...
adept99 Posted October 24, 2019 Report Share Posted October 24, 2019 On 10/19/2019 at 10:06 PM, rickeieio said: Find a tank that will fit correctly. Gravity is much more reliable than pumps. Yeah, seems to me there is even a Law about that... Quote Paul & Paula + Daisy the amazing wiggle worm dog... 2001 Volvo 770 Autoshift, Singled, w/ Aluminum Bed - Toy Draggin 2013 395AMP XLR Thunderbolt Toy Hauler 2013 Smart Passion 2012 CanAm Spyder RT 2013 Harley Davidson Street Glide Link to comment Share on other sites More sharing options...
