scubadave Posted October 7, 2019 Report Share Posted October 7, 2019 (edited) 99 Volvo VNL610 with Cummins N14. Drove about 150 miles this morning and all of a sudden the alarm sounds, no red triangle and no red lights on the air pressure gauges. Pressure reading on both gauges about 105 psi. Alarm sounded for a couple minutes then stopped, air pressure increase towards the end of the alarm. Again about 15 minutes later the alarm came on again but lasted for less than 5 seconds, this time pressure reading about 115. Thus happened a total of about 5 times then nothing further. Drove an additional 30 miles until stopping and everything OK. Any idea what may be causing this? Edited October 13, 2019 by scubadave Quote cat called Anne May Lifetime SKP member 93117 2021 Renegade Classic 45' DD13 with a DT12 Link to comment Share on other sites More sharing options...
rpsinc Posted October 7, 2019 Report Share Posted October 7, 2019 Might it correspond with the pressure relief valve? Quote Marcel Link to comment Share on other sites More sharing options...
geodog Posted October 7, 2019 Report Share Posted October 7, 2019 I would start by replacing the governer. ShortyO Quote Link to comment Share on other sites More sharing options...
chief916 Posted October 8, 2019 Report Share Posted October 8, 2019 My rig did the same thing 2 weeks ago. It's a 1997 Volvo WIA 64. Had my mechanic check it out....he changed out my pressure relief valve. Left the next day from Snow Hill NC.......im now in Fresno CA. Everything works fine. The pressure relief valve was 300 bucks and 91 bucks for install. Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 8, 2019 Report Share Posted October 8, 2019 Replace the governor. It's a 5 minute job at a park, or a 10 minute job on the side of the road dodging traffic. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
chief916 Posted October 9, 2019 Report Share Posted October 9, 2019 19 hours ago, Alie&Jim's Carrilite said: Replace the governor. It's a 5 minute job at a park, or a 10 minute job on the side of the road dodging traffic. X2. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 9, 2019 Report Share Posted October 9, 2019 Please explain the governor comments. The gauges were showing above 100 psi, and the alarm shouldn't come on until the system pressure falls to roughly 60 psi. This sounds more like a pressure switch/sensor or wiring issue than a governor issue. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
hone eagle Posted October 9, 2019 Report Share Posted October 9, 2019 26 minutes ago, Darryl&Rita said: Please explain the governor comments. The gauges were showing above 100 psi, and the alarm shouldn't come on until the system pressure falls to roughly 60 psi. This sounds more like a pressure switch/sensor or wiring issue than a governor issue. do they warn also of over pressure? Quote 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 9, 2019 Report Share Posted October 9, 2019 3 hours ago, hone eagle said: do they warn also of over pressure? No. PSV's job. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
rickeieio Posted October 10, 2019 Report Share Posted October 10, 2019 Gotta agree with Darryl's signature....... " Darryl is right." Probably.😁 Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
scubadave Posted October 13, 2019 Author Report Share Posted October 13, 2019 After about 1300 miles after a new governor the alarm sounded twice for about 2 seconds. Today the compressor would cycle about every 9 minutes, much better than the 2 minutes before the governor change. Since the mechanic mentioned a filter in the air dryer, is their such a thing and if so, where might it be located on a 99 VNL610? Dave Quote cat called Anne May Lifetime SKP member 93117 2021 Renegade Classic 45' DD13 with a DT12 Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 13, 2019 Report Share Posted October 13, 2019 49 minutes ago, scubadave said: After about 1300 miles after a new governor the alarm sounded twice for about 2 seconds. Today the compressor would cycle about every 9 minutes, much better than the 2 minutes before the governor change. Since the mechanic mentioned a filter in the air dryer, is their such a thing and if so, where might it be located on a 99 VNL610? Dave On the inside of the drivers frame rail underneath. About at the location of the drivers side fuel fill door. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 13, 2019 Report Share Posted October 13, 2019 The black part on here: Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Jack Mayer Posted October 14, 2019 Report Share Posted October 14, 2019 I would doubt that the desiccant cartridge would be the culprit. But if you have not changed it you should. Quote Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 14, 2019 Report Share Posted October 14, 2019 6 hours ago, scubadave said: After about 1300 miles after a new governor the alarm sounded twice for about 2 seconds. Today the compressor would cycle about every 9 minutes, much better than the 2 minutes before the governor change. Since the mechanic mentioned a filter in the air dryer, is their such a thing and if so, where might it be located on a 99 VNL610? Dave You've got a leak somewhere, if your compressor is cycling that fast. The vent on the dryer may be an issue, but there's a leak somewhere. And, you've still got an issue wwith the alarm. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
scubadave Posted October 14, 2019 Author Report Share Posted October 14, 2019 Where might I find the sensor for the alarm on the truck and any Idea it may look like? Quote cat called Anne May Lifetime SKP member 93117 2021 Renegade Classic 45' DD13 with a DT12 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 14, 2019 Report Share Posted October 14, 2019 Scroll down on the Heavy Hauler Resource Guide to find the wiring diagrams specific to your truck. Some of them are integrated to the gauges, others have dedicated switches under the dash. There will be more than one sensor, one for the primary tank, and one for the secondary. They both trigger the same alarm, so you need to check both systems. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
podwerkz Posted October 22, 2019 Report Share Posted October 22, 2019 Does that alarm sound just like your door-ajar warning? If so, you may have a fault in one of the door switches. Quote Nothing to see here. Link to comment Share on other sites More sharing options...
Flying Finn Posted November 2, 2019 Report Share Posted November 2, 2019 You may want to check brake chambers. The "pancake" rubber baffle inside the rear chamber was old and started leaking. Quote Link to comment Share on other sites More sharing options...
Parrformance Posted November 3, 2019 Report Share Posted November 3, 2019 On 11/2/2019 at 10:51 AM, Flying Finn said: You may want to check brake chambers. The "pancake" rubber baffle inside the rear chamber was old and started leaking. $3.74 @ Napa in Florida. Bought one of the pancakes to have on hand when traveling. Made sure to tell the wife it's NOT a dog bowl. Quote 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
