alan0043 Posted October 20, 2019 Report Share Posted October 20, 2019 Hi Roger, Thank you for posting your pictures. It will be a help to me too. Thank you again, Al Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 20, 2019 Report Share Posted October 20, 2019 Not Roger, but the angle iron takes up a little room in the hinge point. This increases the angle of the hinge slightly, while decreasing the ramp to deck angle. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
rdickinson Posted October 20, 2019 Report Share Posted October 20, 2019 D&R is correct, you decrease the angle at the deck end but increases it at the dirt end. I generally put some 2x8 material under the dirt end to raise everything up and decrease the ramp end even more. Also you may not be on level ground...the passengers side slopes away from the drivers side which works against you. This helps as well as leaving the A frame in to stop the car from rolling off the other side. The chocks should stop it but I like the insurance. It's un nerving to have the car come up on the deck then start rolling toward the other side. Not all Smarts have the same clearance and the underbody parts are just held on with plastic clips which can be ripped off pretty easily. As it has been said, it is all about mitigating risk. As mentioned before, there was the original way of doing it and modifications done since to make things easier. I have pics of all this or these as well. It will take the guessing out of the procedure. Others have ideas as well, not to say mine is the only way. let me know if you want more plus the explanations. Quote Link to comment Share on other sites More sharing options...
rickeieio Posted October 21, 2019 Report Share Posted October 21, 2019 8 hours ago, rdickinson said: Not all Smarts have the same clearance Not to mention the suspension compression factor if Round Boy is in the saddle. Susan drives ours on/off.🤔 Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
