SWharton Posted September 27, 2019 Report Share Posted September 27, 2019 Just came back from Alaska and needed new fronts. Original size is 235/80 22.5. I want to put on 265/75 22.5. Plenty of space. Any problems with doing this? Quote Link to comment Share on other sites More sharing options...
FL-JOE Posted September 27, 2019 Report Share Posted September 27, 2019 Don't have any idea what Class A you have, gas/diesel, F53 frame or air suspension? I am guessing going with a smaller wider tire wouldn't cause any issues. Wonder what size the original tires were suppose to be? Quote Joe & Cindy Newmar 4369 Ventana Pulling 24' enclosed (Mini Cooper, Harley, 2 Kayaks) Link to comment Share on other sites More sharing options...
SWharton Posted September 27, 2019 Author Report Share Posted September 27, 2019 WE have a Winnebago F53. Original size 235/80. This of course is a Michelin only size. GRRRRR.... so most people switch to the 245/75, a more standard size. We have been weighed and the 245 would work but I feel a lot more comfortable with the 265 and its weight capacity. Just wanted to check with those in the know if thee was something inherently wrong with doing this. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 27, 2019 Report Share Posted September 27, 2019 Looks like it's a little under an inch taller, and a little over an inch wider. Your spedo/odometer will be slightly off, but only slightly. From here. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
SWharton Posted September 27, 2019 Author Report Share Posted September 27, 2019 That's kind of what I thought, no big deal. Peace of mind. Quote Link to comment Share on other sites More sharing options...
Bill Joyce Posted September 28, 2019 Report Share Posted September 28, 2019 You can get the engine manufacturer to adjust the speedometer. When we changed tire sizes Cummins made the computer change. Quote 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 28, 2019 Report Share Posted September 28, 2019 I zoned when they said they were looking for fronts only, but Bill is correct. Some tire shops can also do it, as part of the sale. In the case of rear tires, that wider tread face may cause sidewall interference, so shop carefully. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
SWharton Posted September 28, 2019 Author Report Share Posted September 28, 2019 Thanks for the speedometer info. Probably not enough of difference to worry about. The tire guy checked and said we had plenty of clearance in the rears. Won't be for a few years yet. We were planning to wait for the fronts until next spring but he had them in stock, fresh date so we decided to take advantage while we were here. Quote Link to comment Share on other sites More sharing options...
filthy-beast Posted September 28, 2019 Report Share Posted September 28, 2019 (edited) Make sure that inch taller and inch wider will not rub on anything at full steering stops both left and right. Edited September 28, 2019 by filthy-beast Quote 2020 Platinum F350 6.7L CC DRW, 2021 Riverstone Legacy 37mre 5th wheel Link to comment Share on other sites More sharing options...
SWharton Posted September 28, 2019 Author Report Share Posted September 28, 2019 We just got them installed and backed into our site with no rubbing. All appears good. Quote Link to comment Share on other sites More sharing options...
Jennifer Ministries Posted January 13, 2020 Report Share Posted January 13, 2020 I wannna suggest you all to take listen as on below attached link. as it can help you a lot knowledge of tire size. lets try and all the best!! https://www.bridgestonetire.com/tread-and-trend/drivers-ed/what-is-the-tire-size-for-my-car Quote Link to comment Share on other sites More sharing options...
TireHobby Posted January 16, 2020 Report Share Posted January 16, 2020 On 9/27/2019 at 4:40 PM, SWharton said: Just wanted to check with those in the know if thee was something inherently wrong with doing this. Without some sort of approval from the vehicle manufacture, it's a safety violation. Quote 38' fiver - Dodge Dually AKA: FastEagle USN Retired - DOD Retired - SSA Retired Link to comment Share on other sites More sharing options...
SWharton Posted January 16, 2020 Author Report Share Posted January 16, 2020 Putting on heavier duty tires would be a safety violation???? FYI. Everyone changes tire sizes since the mfgs. do not make the same size tires, especially Michelin who makes numerous odd size tires. Quote Link to comment Share on other sites More sharing options...
jblo Posted May 12, 2020 Report Share Posted May 12, 2020 I would think only going to a lesser capacity tire than was specced by the mfg would be a problem, not upsizing. Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted May 13, 2020 Report Share Posted May 13, 2020 On 9/27/2019 at 7:10 PM, Darryl&Rita said: Looks like it's a little under an inch taller, and a little over an inch wider. Your spedo/odometer will be slightly off, but only slightly. From here. He said fronts. Unless he has a GMC MH it doesn't matter. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Ray,IN Posted May 13, 2020 Report Share Posted May 13, 2020 On 1/16/2020 at 10:41 AM, SWharton said: Putting on heavier duty tires would be a safety violation???? FYI. Everyone changes tire sizes since the mfgs. do not make the same size tires, especially Michelin who makes numerous odd size tires. No, no violation of any kind. Just like putting wider/different tires on your hotrod back in the day. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 13, 2020 Report Share Posted May 13, 2020 On 9/28/2019 at 8:15 AM, Darryl&Rita said: I zoned when they said they were looking for fronts only, Thanks, Ray. Not like I wasn't already called out on it. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Ray,IN Posted May 14, 2020 Report Share Posted May 14, 2020 On 5/12/2020 at 9:30 PM, Darryl&Rita said: Thanks, Ray. Not like I wasn't already called out on it. I apologize, I didn't mean to be insulting, sorry. Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 14, 2020 Report Share Posted May 14, 2020 All good, Ray. We've both been around here long enough to know better. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
