Alie&Jim's Carrilite Posted September 23, 2019 Report Share Posted September 23, 2019 Does anyone have a part number for the aftermarket fan for the front radiator on the gen 2 Smarts? And does the front clip need to be removed to install it or can it be done thru the access panel? Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Jim & Wilma Posted September 24, 2019 Report Share Posted September 24, 2019 The fan I used is Flex-A-Lite 394 S-Blade 14" . You have to remove both fenders and the front panel. There are YouTube videos describing how to remove them. It was pretty easy but helps if you have someone assist because panels are a bit long to single hand. See this post for some additional details: Quote Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 24, 2019 Author Report Share Posted September 24, 2019 1 hour ago, Jim & Wilma said: The fan I used is Flex-A-Lite 394 S-Blade 14" . You have to remove both fenders and the front panel. There are YouTube videos describing how to remove them. It was pretty easy but helps if you have someone assist because panels are a bit long to single hand. See this post for some additional details: Awesome! Thanks Jim Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted September 24, 2019 Report Share Posted September 24, 2019 Jim I do not have the numbers from the fan. However, it was bought at O' Reilys auto parts and is a 12" fan they also have 10" fans but I went with the big one. The front end absolutely has to come off. Look up the directions online. It is not hard but a second person to help lift it off certainly helps. I removed the front end the first time in 45 minutes but I work slow and read directions. The second time it only took about 20 minutes because I knew what to do. Next tips. Do not cut off the plug from the original fan connection. If for some reason the job has to be done by a shop it is much easier to connect. Also be VERY careful where you drill holes for the bracket you build to hold the fan. There are lines running through the frame in places you would never guess. And when you hit one the shop will have to replace the evaporator also. Don't ask how I know this. Brad Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Nuke-E Posted October 4, 2019 Report Share Posted October 4, 2019 On 9/24/2019 at 6:13 PM, Brad & Jacolyn said: Also be VERY careful where you drill holes for the bracket you build to hold the fan. There are lines running through the frame in places you would never guess. And when you hit one the shop will have to replace the evaporator also. Don't ask how I know this. That sounds like there's a bill to prove that you learned all about it. Ouch. On 9/23/2019 at 6:36 PM, Alie&Jim's Carrilite said: Does anyone have a part number for the aftermarket fan for the front radiator on the gen 2 Smarts? And does the front clip need to be removed to install it or can it be done thru the access panel? It's fairly easy to get the front stuff out of the way. While you're in there, it's a good time to upgrade the headlight projectors and polish the lenses/replace the housings--most of the same stuff has to come off. Quote 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted October 5, 2019 Report Share Posted October 5, 2019 If you are coming to Hutch it could become a project. I know at least one bad spot to drill a hole. Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Nuke-E Posted October 6, 2019 Report Share Posted October 6, 2019 22 hours ago, Brad & Jacolyn said: If you are coming to Hutch it could become a project. I know at least one bad spot to drill a hole. How many volunteer Smarts do we need to find the rest of the bad spots to drill? Quote 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 6, 2019 Author Report Share Posted October 6, 2019 On 10/5/2019 at 1:52 PM, Brad & Jacolyn said: If you are coming to Hutch it could become a project. I know at least one bad spot to drill a hole. Not going to make it.... that 4 letter word that starts with W has a grip on us this year. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted October 7, 2019 Report Share Posted October 7, 2019 Sorry you won't be here. 7 have arrived so far. Brad Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
HERO Maker Posted October 8, 2019 Report Share Posted October 8, 2019 On 10/6/2019 at 3:30 PM, Alie&Jim's Carrilite said: Not going to make it.... that 4 letter word that starts with W has a grip on us this year. Wimp? Wuss? ..... 😁🤣😉 Too bad. Take care and don't w... too hard. Quote Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted October 8, 2019 Author Report Share Posted October 8, 2019 4 hours ago, HERO Maker said: Wimp? Wuss? ..... 😁🤣😉 Too bad. Take care and don't w... too hard. Gotta keep WORKING so all ya'll get your SS checks next month... 😁 Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted December 15, 2019 Author Report Share Posted December 15, 2019 Update- Until now we haven't needed any AC, but we are now in the Phoenix-Chandler-Mesa area, or actually just south in Maricopa/Casa Grande and it is a bit warm still, especially with that huge front windshield. So I have the fan, and I've had the front end off before to install a Blue Ox tow bar, but above Brad mentions not cutting the plug off from the original fan to wire to the replacement. So how has everyone wired the fan in? Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted December 15, 2019 Report Share Posted December 15, 2019 Jim, cut between the fan and the plug. You just need to make sure you don't cut off the harness side of the plug. By cutting the wires on the fan side and making the connections, a factory fan can still be used. Quote 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
Jim & Wilma Posted December 15, 2019 Report Share Posted December 15, 2019 Jim, as I recall, I reached in as far as I could and cut the cable. I abandoned the old fan and remaining cable in place. I spliced an additional length of cable to reach the new fan. Quote Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted December 15, 2019 Report Share Posted December 15, 2019 Like the guys said just cut into the existing fan wiring but leave the plug in place so it can still be used if necessary. And when mounting the fan use short screws. Brad Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted December 15, 2019 Author Report Share Posted December 15, 2019 13 hours ago, GeorgiaHybrid said: Jim, cut between the fan and the plug. You just need to make sure you don't cut off the harness side of the plug. By cutting the wires on the fan side and making the connections, a factory fan can still be used. 13 hours ago, Jim & Wilma said: Jim, as I recall, I reached in as far as I could and cut the cable. I abandoned the old fan and remaining cable in place. I spliced an additional length of cable to reach the new fan. 1 hour ago, Brad & Jacolyn said: Like the guys said just cut into the existing fan wiring but leave the plug in place so it can still be used if necessary. And when mounting the fan use short screws. Brad Got it! Thanks! When I put the tow bar apparatus on, I didn't look to see how long the pigtail on the fan was. We were in a little bit of a rush. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
