dell Posted September 16, 2019 Report Share Posted September 16, 2019 When the battery is running down will that set off the Carbon Monoxide/ Propane tester? Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted September 16, 2019 Report Share Posted September 16, 2019 yep...... Quote Link to comment Share on other sites More sharing options...
dell Posted September 16, 2019 Author Report Share Posted September 16, 2019 So I replaced the battery on the camper and the detector is still going off. I checked the battery and it is losing charge, which makes the detector go off again. I plugged in the camper which charged the battery back up and the detector quit going off. Any suggestions? Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted September 16, 2019 Report Share Posted September 16, 2019 (edited) Are you sure the charger is actually charging the battery? Could be the converter is not charging the battery but is supplying 12vdc when on shore power and this is why the detector is acting the way it is. What size battery bank do you have? How long after disconnecting from shore power does the detector go off? What else may you be running off of your battery system? RV fridge, lights, inverter, etc? Edited September 16, 2019 by DesertMiner Quote Link to comment Share on other sites More sharing options...
dell Posted September 16, 2019 Author Report Share Posted September 16, 2019 There is nothing else running off the battery when it is sitting in my driveway, not in use. I just replaced the battery last weekend since the other one was dead. The battery runs down within a couple of days if I don't plug in the camper. I put the same size battery in it that it came with. I don't know what you mean by battery bank. Quote Link to comment Share on other sites More sharing options...
DesertMiner Posted September 16, 2019 Report Share Posted September 16, 2019 Do you have a battery disconnect switch? Quote Link to comment Share on other sites More sharing options...
dell Posted September 16, 2019 Author Report Share Posted September 16, 2019 I'll have to check. Quote Link to comment Share on other sites More sharing options...
StraitRVing Posted September 17, 2019 Report Share Posted September 17, 2019 My house batteries were only two years old yet they were going bad. Fridge began to do weird things, LP/CO detector developed a mind of its own, and a few other issues. I checked water levels and added distilled water as needed. More checks during the summer when the heat and humidity were high. I didn't think it was the batteries due to them only being two years old. Voltage checks showed one battery was around 12.04Vdc and the other at 11.98Vdc. Took the batteries and had them tested and found out that they were weak and each has a cell that was going bad. Replaced them and all the problems are now gone. Quote Richard "Doc" Strait, USN Retired 2017 Coachmen Leprechaun 319MB Point of Contact for the Military, Veterans, and Gold Star Families BOF Link to comment Share on other sites More sharing options...
Kirk W Posted September 17, 2019 Report Share Posted September 17, 2019 You may find this thread in the General forum about CO/LP alarm issues to be helpful. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
